Like Tree5Likes
SC10 4x4 Thread
Old 08-10-2012 | 12:51 PM
  #28141
vito's Avatar
http://prolineracing.com/short-cours...tires-trencher
vito is offline
Old 08-10-2012 | 12:53 PM
  #28142
any one using the mip bypass valve kit ?
twisted is offline
Old 08-10-2012 | 01:49 PM
  #28143
fq06's Avatar
Originally Posted by 9turn
it not traslated i cant spell delexic but i can tune the shit out of a car
Damn! That's a bad case of dyslexia!
Spell check?
Most of your posts are comprehendible, but the one where you posted your setup was something that I got 2 lines through and quit. I'm sure everyone else did too.
So thanx for sharing what could be good info, but I don't think anyone will benefit from it.
fq06 is offline
Old 08-10-2012 | 01:54 PM
  #28144
Cain's Avatar
anyone know about the aka rims?
If you can fill out the setup sheet and post that can help.
Cain is offline
Old 08-10-2012 | 02:01 PM
  #28145
fq06's Avatar
I thought they did, but I don't see them on their site.
Avid makes a really nice +3 rim though.
http://www.avidrc.com/product/2/whee...-B-wheels.html
fq06 is offline
Old 08-10-2012 | 02:42 PM
  #28146
For shits and giggles here is my bone stock basher sc10 4x4. Doesn't handle as well as my other one but its sure fun to beat up. My little track really needs some attention haha! It is so frigging rough and hard to keep anything under control with all the ruts, and rocks poking up out of the ground lmao!
http://www.youtube.com/watch?v=CFqRo...yer_detailpage
RC-1 is offline
Old 08-10-2012 | 04:00 PM
  #28147
yes werth every cent i posted my setup 2 pages back
9turn is offline
Old 08-10-2012 | 04:03 PM
  #28148
i will scan a copy 1 min
9turn is offline
Old 08-10-2012 | 04:30 PM
  #28149
fq06's Avatar
Originally Posted by vito
my truck looks fine iam hit mid 30 mph with 62 12 gearing and not hot at all
You should be 13/62 with that motor. You will pick up the top speed a few mph and will make the motor work harder on the bottom end making the motor produce more torque. You can get more torque with a bigger gear, just less wheel spin than with smaller gear (school me if I'm wrong). Guess more torque at the motor, not torque at the wheels. You probably don't get much wheel spin on your street, but in the dirt that does apply.
fq06 is offline
Old 08-10-2012 | 04:32 PM
  #28150
setup with mip pistons
9turn is offline
Old 08-10-2012 | 04:36 PM
  #28151
wc when u ran with bk how did your lap times compar
9turn is offline
Old 08-10-2012 | 04:44 PM
  #28152
cyljock's Avatar
that first vid dive like shit looks like bmain 2wd do you have a vid of your truck
Gee, thanks. That was my sc10's debut that day. First time ever wheeling a 4x4.
cyljock is offline
Old 08-10-2012 | 04:59 PM
  #28153
vito's Avatar
thanks i need to gear up some.
vito is offline
Old 08-10-2012 | 05:36 PM
  #28154
vito's Avatar
dose the motor need to come out to gear up to 15 tooth. iam at 110 temp in the street.
vito is offline
Old 08-10-2012 | 05:41 PM
  #28155
fq06's Avatar
Depends on how you go about it.
I use a ball end 2mm hex and everything stays in place.
Some dremmel a section out of the belt guide so you can go straight into the pinion screw without needing a ball end hex driver.
Some drill a hole in the bottom of the chassis so you can get a hex driver up to the pinion screw.
Some take the motor out regardless of pinion size if they haven't figured out the above methods.
A 15t pinion may not even fit through the motor mount plate and you may not be able to put the pinion on the motor and then mount the motor on the plate. You may need to leave the motor in and tighten the pinion.
fq06 is offline
