Serpent 811E Buggy Thread >
Like Tree5Likes
Old 08-08-2012 | 02:11 PM
  #2851
ATMHOBBY's Avatar
Thanks guys. I used the dremell (sp) to grind down one of the serpent metal servo horns. I think it will work well.
ATMHOBBY is offline
Old 08-09-2012 | 05:30 AM
  #2852
weavty1's Avatar
Thumbs up
Originally Posted by w_dupree
Also a +1 with the Hot Bodies servo horn. Love it!
weavty1 is offline
Old 08-09-2012 | 05:17 PM
  #2853
pilotwings119's Avatar
What size are the holes in the Serpent 8-hole conical pistons? Part 600350
pilotwings119 is offline
Old 08-09-2012 | 05:35 PM
  #2854
dirtydan's Avatar
1.1mm
dirtydan is offline
Old 08-09-2012 | 07:06 PM
  #2855
nogarats's Avatar
Originally Posted by Magnus F
Here is my video now in pretty good quality.
Its about 3 month since and my car is way better now:-)
http://www.youtube.com/watch?feature...&v=WMpFM5oivxk
Thanks, that makes it much more easy to understand the type of track one is racing on!
nogarats is offline
Old 08-09-2012 | 07:07 PM
  #2856
bigjayjay1's Avatar
There have been a few people asking for my setup I haven't forgotten just been dam busy to lay down on a setup sheet will do it by Fri and I'll send over so you have for the weekend sorry guys
bigjayjay1 is offline
Old 08-10-2012 | 01:00 AM
  #2857
They are 1.2mm
Magnus F is offline
Old 08-10-2012 | 11:23 AM
  #2858
PurevilSerpent's Avatar
Went with the Hot Bodies Aluminum horn as mentioned further back in the posts. Fits perfectly, no clearance issues.
PurevilSerpent is offline
Old 08-10-2012 | 11:24 AM
  #2859
No problem Jay, folks get busy, i know! Thanks for your help thus far.
Old 08-11-2012 | 03:03 AM
  #2860
Originally Posted by ATMHOBBY
Hey Guys,
My friend and I are both having the same issues of the small plastic gear adapter for the steering servo stripping after a while. I tried to fit a serpent metal steering horn, but when I put the locknut on to fasten, the center brace gets in the way.
Does anyone have a solution?
Thanks.
its close but io dremel used the sanding bit just to smooth it down a bit,and it misses
No Idea!! is offline
Old 08-11-2012 | 03:02 PM
  #2861
I think the plastic arm (where your finger is) is installed upside down.... Unless you just had it installed up side down in your picture (and not running on the car that way)....Quite a few guys run them upside down like you show it, (by mistake), cause when you press the front ball stud thru...for the plastic arm to end up in the correct orientation, it "has" to be pressed thru from the "smaller" holed side of the arm, and not the slightly larger tapered side...the way it should have been manufactured on that piece (IE: larger hole on the opposite side).....
not sure how big of a difference this makes running(prob not much), but when it's flipped over from the way the book shows it...it looks to exhibit more of an arcing motion to the linkage, rather than a more precise straighter motion.... Joe
Joe B is offline
Old 08-11-2012 | 03:39 PM
  #2862
Also, another option (when running aluminum servo horns) is to get rid of all the plastic shims underneath the servo anchor screws altogether (further reducing servo flex), and run your plastic arm to the "outside" of your aluminum servo horn (instead of inside)..... this setup (with most servos) will allow the arm to be aligned nice and straight... And not contact anything at all........ Joe
Joe B is offline
Old 08-12-2012 | 04:32 AM
  #2863
Has I have just swapped out servo's for Orion Vds, had a Futaba in, just going Hv,and waiting on my HB servo horn will be removing the spacers,has the vds doesn't sit right with the spacers,and the Fullforce clamps don't clamp had good either,mmm
So will be on the other side
Old 08-12-2012 | 10:55 AM
  #2864
My Serpent 811BE painted by Neesh!
Made in Hawaii.
Awesome as usual!
Honu is offline
Old 08-12-2012 | 12:14 PM
  #2865
Ross71's Avatar
Quick Question, does anyone know if the Ezrun 150amp ESC fit Ok in the serpent.
Ross
Ross71 is offline
