Serpent 811E Buggy Thread
#2776
#2777
Honestly I'm searching for a good setup. I've got 5-5-3 in the diffs. I run blue springs up front been running green in the rear. I used webbed bladders and 8 hole conical pistons which I'm drilling out to 1.3, normally I use 40wt front and I'm going to try 25wt rear. I normally run indoors medium size track. Hard pack low dust normally somewhat wet. The rear feels like its drug around by the front of the car. I haven't touched camber or toe from the box settings. Here's my email if it's easier to communicate that way: [email protected]
#2779
I know I already asked this about the chassis but if I decided to use Alu shock towers instead of the stock ones, are the king heads or m2c ones better than optional serpent ones? I like the look of carbon more bt I just don't feel like preparing them and all that lol
#2780
Yeah, I would run 1 degree of camber and try the 7k oil in the diff. Thicker oil has worked better for me in the shocks than thin. The car rolls alot and the thinner oil made the car darty for my taste. I went as high as 40 wt in the rear and 45 in the front. I settled on 35 rear and 45 front.
#2781
I put the Serpent front aluminum tower on the car. Quality is nice and the look is hard to beat. I left the rear carbon tower on the car as the wing protects it. Replace the plastic nuts with aluminum lock nuts that hold the towers on.
#2784
#2790
5Likes
