Serpent 811E Buggy Thread
#2761
Well.....just put in an order for 2 B811E's and a bunch of (u)necessary option parts @ Amain
Can't wait to get back into 1/8 racing again after a 10 year break.
Hopefully the Serpent should fill the void just fine after getting rid of my B4.1 & B44.1 earlier this year
Bent
Bent
#2763
#2764
How much droop? The serpent sheet shows the measurement from the center of the tower screw to what looks like the top of the pin that holds in the shock in the arm. I was under the impression it was measured center to center?
#2765
On dusty tracks, I give it all the droop screws will allow before allowing the shocks to overextend. If the track is dusty and loose, You dont want the droop screws to touch the chassis when it rolls. Once they touch, the car will lose traction. For high bite, I reduce the uptravel to help the car rotate and be more free. When its loose, I dont want to limit or break traction anywhere.
#2767
#2769
#2770
#2772
Thinner center diff oil will make the car easiere to drive in bumpy conditions, but will give less acceleration
#2774
I don't see how you guys can run stiff springs in the back and soft up front. Im running on a large outdoor track and run the softest springs in the back and the hardest in the front. Even with soft springs in the rear I have to be careful not to give it too much throttle coming out of the corner.
I also don't run a rear swaybar, max rear toe, and zero anti squat. Thats the only way I can get the rear end to hook up.
#2775
Here is what i am running on my car. Track is dusty and can be loose so my setup wont be the best for higher bite. My car is very easy to drive and not loose at all.
Front:
Blue shock spring w/ 45wt. Losi oil
1 degree of camber
0 toe
middle camber link location on tower inside(longer)
2.5 mm sway bar
max droop (just make sure pistons do not bottom out. adjust droop screw to stop this)
5000 diff oil
2nd hole in from outside shock mount on tower
Inside shock mount hole on arms
28.5mm ride height
Center diff 7k oil
Rear:
box setup for hinge pin inserts(I believe it is 3 deg rear toe and 2 degrees anti squat)
3k diff oil
1 degree camber
35 wt. losi oil
yellow rear springs
camber link in middle hole on hub and inside middle hole on tower
shock mount on tower 3 holes in from outside
wheelbase full long
29mm ride height
Max droop without bottoming out piston
2.5mm sway bar
I am running J concepts Hybrid green compound(soft). I am using 8 hole 1.2mm shock pistons. 6 hole 1.3mm will be fine also.
I have a very linear feel set on the speed control so its not notchy feeling.
The car was very easy to drive, jumped extremely well.
Front:
1 degree of camber
0 toe
2.5 mm sway bar
5000 diff oil
28.5mm ride height
Center diff 7k oil
Rear:
3k diff oil
1 degree camber
35 wt. losi oil
yellow rear springs
wheelbase full long
29mm ride height
2.5mm sway bar
5Likes
