KO Propo EX-10 EURUS >
Old 07-31-2012 | 09:53 PM
  #1516
gelshocker's Avatar
Originally Posted by silvalis
Thanks, got it. It was the latter - need to have it in "norm" mode. CH3/CH4 aren't operational in High Speed/Advanced.
Any reason why it's like this (904fh/411fh)? Seems sort of lame...
Umm.. sorry for asking, how can I run a transponder in Advance mode then?
gelshocker is offline
Old 07-31-2012 | 09:56 PM
  #1517
A transponder does not communicate with your radio.
So, do you mean a receiver in Advance mode?
Still Bill is offline
Old 07-31-2012 | 10:14 PM
  #1518
gelshocker's Avatar
Yeah sorry for the poor worded question: Are the rx CH3/CH4 operational in the fastest response setting (Advanced)? For attaching a transponder and glitch buster say. Would be silly if not. Thanks,
Old 08-01-2012 | 12:20 AM
  #1519
Hi guys, is the Eurus FH-SS still worth getting over the new EX-1 KIY?
The Eurus's selling points are its more balanced feel (vs. top heavy feel of the KIY), lighter weight (?), also has 3D trigger / drop down wheel, as many functions as the KIY (?), LiPo / Life ready without mod, almost a Rx cheaper.
Please share your thoughts. Thanks!
Hotseat is offline
Old 08-01-2012 | 08:55 AM
  #1520
dexon555's Avatar
I think it's a personal choice, I still prefer the Eurus, but that's my opinion.
Many people have changed over to KIY and love it.
dexon555 is offline
Old 08-01-2012 | 07:41 PM
  #1521
gelshocker's Avatar
Anyone please? Thanks,
Old 08-02-2012 | 09:18 AM
  #1522
In Advanced mode only channel 1 & 2 are controlled by the Tx.
Channel 3/4 and the battery slot will always provide power but no signal control in this mode.
KO PROPO Staff is offline
Old 08-02-2012 | 09:39 AM
  #1523
gelshocker's Avatar
Thanks for the reply. So I can run a transponder (passive device, no tx signal control needed?), but not a mechanical brake, in CH3 on a Tekno RC EB48? I am correct in my understanding?
Old 08-02-2012 | 12:46 PM
  #1524
No idea about the mech brakes, but you are correct about the transponder. I have run mine on both CH3 and CH4.
kazuaki is offline
Old 08-02-2012 | 06:37 PM
  #1525
gelshocker's Avatar
Thanks, I guess I can't install on/off lights and frantically rotate Wild Willy's head in ch3/4 then! Cheers,
p.s. any idea if this limitation is 'fixed' in KIY?
Old 08-03-2012 | 07:33 AM
  #1526
By "fixed" I don't understand what you are saying. The advance mode is the fastest response (4.0ms) and only uses two channels since there is less information to be transmitted. High speed response mode would be the same as this is 6.0ms.
If you want to use the 3/4 channels you would have to set the response to normal which is 8.0ms. This response would still require the use of digital servos since analog servo cannot process a signal this fast.
This I believe is true for all the high end transmitters currently on the market including the EX-1 KIY.
Old 08-03-2012 | 09:05 AM
  #1527
gelshocker's Avatar
Thanks for reply and explanation
Old 08-05-2012 | 07:03 PM
  #1528
gelshocker's Avatar
Hi KO Propo staff, you have pm. Thanks
Old 08-05-2012 | 11:56 PM
  #1529
B00t13g's Avatar
How does everyone charge their protek lipo receiver packs since the power and ground are in opposite locations while in the radio?
B00t13g is offline
Old 08-06-2012 | 01:15 AM
  #1530
andrewdoherty's Avatar
Wink
Come look at mine Mackie.
andrewdoherty is offline
