Like Tree5Likes
SC10 4x4 Thread
Old 07-29-2012 | 10:58 PM
  #27451
CraigMBA's Avatar
Originally Posted by hyperSC82
You need to bring that thing out and run it we need more "fast guys" in 4x4sct
I put earplugs in when that class is on the track. Seriously, why is everyone else's truck loud like a chainsaw on meth?
My plan is to race 2w and test 4w SC.
CraigMBA is offline
Old 07-30-2012 | 06:26 AM
  #27452
the 1410 magnits are good to 180-200c not farinhite i would be more woryed about the wires insalation welting but you can smell it when this happen i trie the old 2pole 5700 castle and it had lots of power but it would make a mamba max thurmal in 5 min of hard diving on the street (drifting) and when checked the motor you could not tuch it so it was over 220f and was starting to smel i know this smel all to well from spl contests the melting point of the plastic is 160-180c
but all this aside the cooler the motor is the more efishent it is and the longer things will last castle makes good stuff and they back it up i just wish they would make a senserd motor i hope this bings things in to prospectiv
tenshock posted a dyno graff of there motor dos any one have it
9turn is offline
Old 07-30-2012 | 06:53 AM
  #27453
ShortCourseOnly's Avatar
I've been running a Ballistic 550 4.5t for a long time in my SC10 4x4. On tight tracks it was cool running a 12t but now I'm running big 8th scale tracks in Brazil. I have no top speed on the long straights and my temps have shot up. I am assuming that I am heating due to high RPMS. Should I go up to 14t or 15t? I read that someone was running this high of a pinion witha 4.5t 550 motor. Can someone provide their experience?
ShortCourseOnly is offline
Old 07-30-2012 | 06:54 AM
  #27454
Wildcat1971's Avatar
Tech Prophet
I run a 14/62 on my local 8th scale track with a tekin 2 pole 550 4.5turn
Wildcat1971 is offline
Old 07-30-2012 | 06:59 AM
  #27455
Cain's Avatar
Originally Posted by Evil Genius jr.
Yes you can.
Thanks!
Originally Posted by twisted
i dremeled part of the belt cover so i can gt my non angled wrench onto the pinion.
Good tip, thanks!
Originally Posted by Jake S
i drilled a hole from the bottom and countersunk it so i just put a normal 4-40 screw and nut on the other side to fill the hole
So you just run the allen driver through the hole to get to the set screw, good tip. may give this a look.
Start with lower sized pinion that you have available that is bigger than the 12 and check temps again.
What people are running boost etc with there pro4s? I have been hearing about people doing this, gearing down then making up top end with boost, super charger, etc.
Cain is offline
Old 07-30-2012 | 07:12 AM
  #27456
Wild Cherry's Avatar
Originally Posted by ryanpatrickgore
Running 12/62 with the reedy 4.5 and it's coming off at 156 after 10-12 minutes. No receiver box. After a 6 min heat it's at about 142*. I would be worried till 180
Yah , me Reedy Sonic 550 never gets warmer than 140 , so who needs fans ?
Maybe 4 poles ?
Guess they need um .....
Wild Cherry is offline
Old 07-30-2012 | 07:41 AM
  #27457
CraigMBA's Avatar
Maybe 4 poles ?
Kinwald uses fans. That's the guy you took out when he was putting you your first lap down.
CraigMBA is offline
Old 07-30-2012 | 07:50 AM
  #27458
Bk ran into my back end ....
How bout some of your results ?
got any yet ?
BTW
How many fan's are you using these days ? LoL !
Old 07-30-2012 | 07:51 AM
  #27459
Evil Genius jr.'s Avatar
Poor WC lol
Evil Genius jr. is offline
Old 07-30-2012 | 07:58 AM
  #27460
I`m not rubbed one bit Evil , Craig can bash me all he wants ...
At least I made the "show" & will again soon ....
Two of those guys I beat last Tuesday are far better than Craig and his antics ...
Both scored A in the Reedy open class.....
Old 07-30-2012 | 08:00 AM
  #27461
I bet I could make the F main at a big race lol.
Old 07-30-2012 | 08:01 AM
  #27462
Tech Prophet
I dont know why you guys give WC a hard time. His information is good if you just filter out the AE fan boy stuff.
Old 07-30-2012 | 08:02 AM
  #27463
Tech Prophet
I made the E once at Mod Nationals? I beat all the cars that broke......
Old 07-30-2012 | 08:04 AM
  #27464
You can make the A someday , takes hard work , lots of practice ...
Or as I said before
Be a Track rat & eat lots Cheese
Old 07-30-2012 | 08:08 AM
  #27465
CraigMBA's Avatar
Because you were slow down the straight. Not to mention its just common racing courtesy to let the leader go by when you are running dead last and going a lap down the first time.
What will that prove? You are still slow in a straight line.
got any yet ?
Sure, but that doesn't change the fact you are down on power which is why you don't need a fan.
BTW
I have one in the chassis from when I was using the 540 motor (same as the one Cameron ran, thanks Cam!).
CraigMBA is offline
