Like Tree5Likes
SC10 4x4 Thread
Old 08-11-2012 | 02:38 PM
  #28201
SOuthernFRIED's Avatar
Swapping to the Durango v2.
SOuthernFRIED is offline
Old 08-11-2012 | 02:46 PM
  #28202
Originally Posted by xxxntwv
Glad you got it figured out.This truck has a lot of potention if you just spend the time to find a steup that fits your driving style.What kind of colling fan is that on your motor.
I don't remember sorry, but with my mods anything fits on there, not that it really even needs it, here a better pic, took the rear chassis brace off altogether.
[IMG][/IMG]
RossNZ is offline
Old 08-11-2012 | 02:59 PM
  #28203
i like how the chassis brace allows for more air to get to the motor.
twisted is offline
Old 08-11-2012 | 03:00 PM
  #28204
That's what I was thinking as well before this weeks racing, or the Losi, but I was happy with my car yesterday racing, all the power to the wheels I needed and stayed nice and straight under full throttle, I feel it needs more weight in it, as it felt a bit "light" thru some of our off camber corners.
I also get the feeling the Rango would suffer from the same on our track, we have big elevation changes and lots of off camber corners, The Losi can power thru with there weight, were I was on tipy toes, but I can fix that, thinking a 3mm steel plate under the chassis will do it. The truck showed me enough to keep trying, biggest issue yesterday was driver error.
RossNZ is offline
Old 08-11-2012 | 03:09 PM
  #28205
Well as you can see there's been lots of mods, looking at making the top brace lighter, and may add a plate under the complete chassis to lower all the weight, it's 95% there.
The guys running the Losi here have spend huge $$$ on them as well, we all need to remember that, for me to change and be up to speed with these guys i'd be out some big cash, and yesterday my truck was very fast, drove around the other trucks down the straight, but lack of weight let me down here and there.
RossNZ is offline
Old 08-11-2012 | 03:17 PM
  #28206
vito's Avatar
my losi gule did not work it a year old thats it
vito is offline
Old 08-11-2012 | 03:39 PM
  #28207
Once you crack open a bottle of CA, I give it 6 months absolute tops before I replace it. It collects moisture and looses its effectiveness.
Krio is offline
  #28208
vito's Avatar
Originally Posted by Wild Cherry
Buy some glue designed for tires Vito ,.
Losi tire glue is used by almost everyone , standard or thin..
the losi gule did not stick to the rims or tires
vito is offline
Old 08-11-2012 | 03:43 PM
  #28209
Wildcat1971's Avatar
I like this stuff
http://www.amainhobbies.com/product_...-Thin-CA-1-2oz
Wildcat1971 is offline
  #28210
Did you clean the rims and tires before hand?
RossNZ is offline
Old 08-11-2012 | 03:45 PM
  #28211
vito's Avatar
yep the gule was old i think its a 1 year old
vito is offline
Old 08-11-2012 | 03:47 PM
  #28212
Matt Trimmings's Avatar
Tire / wheel bead still needs to be cleaned. Glue will also last longer if kept in the fridge...or at least thats what i heard
Matt Trimmings is offline
Old 08-11-2012 | 03:48 PM
  #28213
That could be your problem, I just use cheap CA clue, if things are cleaned well you should have no issues.
RossNZ is offline
Old 08-11-2012 | 03:49 PM
  #28214
vito's Avatar
there stuck now need to pick up new gule and bands
vito is offline
Old 08-11-2012 | 03:51 PM
  #28215
Do bent A arms effect handling at all?
They move free, just a slight bow in them all.
RossNZ is offline
