Like Tree5Likes
SC10 4x4 Thread
Old 07-25-2012 | 08:07 AM
  #27061
BorackBasher's Avatar
Borack, I too the 8mm off mine also. I am going zero shims rear with the short link and 5mm up front with a long link. Going to try that. And yes, a fast servo makes the truck impossible to drive imp. I have the speed on mine turned down to 60% of max.
why are you putting a shorter link in the rear and long link in the front?
BorackBasher is offline
  #27062
Cain's Avatar
This is just me here, but I would think the 8mm mod from what I have read if you are on loose conditions would really make your vehicle squirrely .
For really fast servos, personally I turn down the EXP I believe thats what its called so its not as fast close to neutral.
Cain is offline
Old 07-25-2012 | 08:31 AM
  #27063
Wildcat1971's Avatar
Tech Prophet
Ok, Borack, I am by no means a tuning master. But this is my understanding.
<td>Longer Front</td>
<td>The front rolls and dives more in turns.<br>Lots of steering in mid-corner.<br>Could make the car hook.</td>
</tr>
<tr>
<td>Shorter Front</td>
<td>The front feels very stable.<br>A little more turn-in, but less steering in mid-corner.</td>
</tr>
<tr>
<td>Longer Rear</td>
<td>More rear traction in turns, and coming out of them.<br>Rear end slide is very progressive, not unpredictable at all.<br>
Make sure that there's enough rear camber though, or you could lose rear traction in turns.</td>
</tr>
<tr>
<td>Shorter Rear</td>
<td>The rear feels very stable. It breaks out later and more suddenly, but if it does, the slide is more controllable.<br>
It makes the front dive a little more, which results in more steering, especially when braking.</td>
</tr>
<tr>
<td>More Angled Front</td>
<td>Turn-in is very agressive.<br>The front feels as if it wants to roll less than the rear.</td>
</tr>
<tr>
<td>More Angled Rear</td>
<td>The rear end is rock-solid while turning in. It feels very confident.</td>
Wildcat1971 is offline
Old 07-25-2012 | 08:32 AM
  #27064
Tech Prophet
well that came out badly, lol.
Old 07-25-2012 | 08:37 AM
  #27065
Tech Prophet
http://users.telenet.be/elvo/
Old 07-25-2012 | 08:41 AM
  #27066
Tech Prophet
sigh, as I re read the text, I am confused lol. I always thought longer links in the front caused more push. And short link in the rear was more traction. Now i am not so sure.
Old 07-25-2012 | 08:54 AM
  #27067
samuelsonmark71's Avatar
Talking about clearing the quad... lol, quad post?
samuelsonmark71 is offline
Old 07-25-2012 | 09:04 AM
  #27068
Tech Prophet
yeah, bad habit. I did some more reading and I think you are right Borak. I have it backwards. Longer links allow for more roll and short links keep it flatter with less camber gain. So I need longer links rear and short front....doh. And the shim help to change the angle and lessen the camber gain. So with the rear are zero shims and longer link, then it should dive in the corners and have more camber gain, thus it should hook up in the corner.
The short links in the front, will give less dive into the corners and the shim with lessen the camber gain and should make the front more forgiving (push). I will need to fix that when i get home.
Old 07-25-2012 | 09:11 AM
  #27069
Wild Cherry's Avatar
Waiting for a quad triple post ....
Wild Cherry is offline
Old 07-25-2012 | 09:14 AM
  #27070
Old 07-25-2012 | 09:16 AM
  #27071
Tech Prophet
Old 07-25-2012 | 09:25 AM
  #27072
ryanpatrickgore's Avatar
Originally Posted by Cain
what made you use the 8mm mod? Correct me if I am wrong but my understanding is people are using this for traction rolling in high bite conditions.
Speaking of which, at what point (ie- the number of shims under the inner ballstud) do you take off the 8mm riser on the rear hub carrier?
What track conditions do you have? What tires? What compounds? Tread or slick? These all are factors. When traction is way up and your running real sticky tiers then it's mandatory for me. Because I'll roll all over the place. If you have poor traction then it's not as necessary.
ryanpatrickgore is offline
Old 07-25-2012 | 09:28 AM
  #27073
Tech Prophet
I run on wet soft clay. And traction can very from corner to corner. I never traction rolled with the mod, but in all honestly, the corners I did roll in, I should have probably slowed down more before the corner. So I took it off.
Old 07-25-2012 | 10:31 AM
  #27074
wow with this all being said.. i am going to try them without... too much info all at once!!! i am so confused now just got back from ae too.. got some new shims and a new updated top shaft to try with the inner coupler
Old 07-25-2012 | 10:32 AM
  #27075
Tech Prophet
ah, your going to try the pinned top shaft?
