RC8Be to RC8.2e Conversion Parts List (Complete)) >
Old 03-10-2012, 08:55 PM
  #31
wingnutz21's Avatar
Originally Posted by BLbound
You can get a new kit in th box from team associated for $275 on their web specials. The kit doesn't have an problems. The newer 8.2 is just a little longer & has a different suspension set up.
Thanks for the reply
wingnutz21 is offline
Old 03-10-2012, 08:56 PM
  #32
wingnutz21's Avatar
Originally Posted by Oasis
The older RC8 is not bad and it's still more than capable of winning..but the the newest version.. the RC8.2e is waaaaaay better on a blown out track, is a lot smoother, jumps better.. It's a much improved product, personally I would wait a while, save your money and get the 8.2e..
Thanks for the reply, your right I should go with the 8.2e.
Old 04-23-2012, 08:33 AM
  #33
Originally Posted by TEXT
Here is a complete part listing if you wanted to convert your RC8Be to an RC8.2e Chassis Setup... http://www.rctech.net/forum/electric...-complete.html
Thanks for posting this, I wish they just made a conversion kit. Thanks again!
MrKahunaXD is offline
Old 04-23-2012, 10:11 PM
  #34
Will 8.2 e bodies fit the original rc8be? If so, which ones?
skoot50 is offline
Old 04-25-2012, 10:19 AM
  #35
baf1's Avatar
Default hello
The A.C.D. mounts are the same for the 8 and 8.2
baf1 is offline
Old 07-19-2012, 10:35 AM
  #36
Bmr4life's Avatar
Trader Rating: 50 (100%+)
Does the new motor mount fit in the RC8Be?
Bmr4life is offline
Old 07-22-2012, 10:04 AM
  #37
MOmo's Avatar
Yes. Should bolt right in. My buddy who is an engineer at AE Says there is no difference in holes and it works on all 3 RC8 frames, SC8, RC8T, and RC8B. I'm looking to update both my T and B with the new ones.
Momo
MOmo is offline
Old 07-22-2012, 11:12 AM
  #38
Bmr4life's Avatar
Momo
I looked into it a little bit, it should fit but there are a couple other parts you have to buy also (not expensive). The real problem for me is it does not accept large pinions. At its cost and limited pinion range, I may as well get another Grid RC mount for a few bucks extra.
Bmr4life is offline
Old 07-25-2012, 10:58 AM
  #39
vfrninja's Avatar
What's the difference between new shock shafts and the old ones? Do I NEED them for the conversion?
Thanks.
vfrninja is offline
Old 07-25-2012, 01:41 PM
  #40
RCW
Trader Rating: 29 (100%+)
Thanks.
The new ones are shorter. If you are using .2 arms and towers, I believe you will have to change the shafts. The .2 springs are shorter also.
RCW is offline
