RC8Be to RC8.2e Conversion Parts List (Complete))
Here is a complete part listing if you wanted to convert your RC8Be to an RC8.2e Chassis Setup...some of these parts you can get away with not having, but most of them I found to be rather important! I hope you guys found this useful. I looked at each an every section just to check and see where these parts were exchanged for different ones that had been improved! Please leave a comment if you have any questions, and I will try and help you the best I can!
#89492 16mm Piston 5x1.1 + 5x1.2
#89554 HD Shock Shaft, 4x26mm
#89555 HD Shock Shaft, 4x36mm
#89556 RC8.2 Shock Boots (Front and Rear)
#89477 RC8B Light Outdrive, Front
#89478 RC8B Light Outdrives, Rear
#89494 RC8B Light Diff Ring Gear, Includes Diff Gasket
#89543 RC8.2 Front Spring Silver (4.3lbs) - Kit
#89547 RC8.2 Rear Spring Silver (3.55 lbs) - Kit
#89485 Aluminum Steering Posts
#89286 RC8 Gearbox Input Cup, Aluminum
#89557 Pin Retainer O-Ring / Boot
#89560 RC8 Rear Center Drive Shaft +3mm
#89481 RC8B Low B Plate - Kit works with #89482, 89553
#89482 RC8B Low B Plate Inserts - Kit works with #89481, 89553
#89553 RC8.2 FR Hinge Pins, TiN - Kit works with #89481, 89482
#89075 RC8 Steering Ballstuds
#89218 3x8mm Washer
#89223 3x8mm SHCS
#89269 Steel turnbuckle, 38mm
#89285 Front Stub Axle, Aluminum
#89380 FT Machined Steering Blocks
#89454 3x12mm SHCS
#89526 50mm Steel Turnbuckle
#89549 RC8.2 Front Upper Arms
#89550 RC8.2 Front Arms
#89558 RC8.2 Caster Blocks
#91069 Shock Mount Pin, Steel
#89224 3x16mm SHCS
#89227 3x28mm SHCS
#89230 Silver Cone Washer
#89284 Rear Stub Axle, Aluminum
#89551 RC8.2 Rear Arms
#89561 Rear Mud Guards
#89538 RC8.2 Front Tower, Aluminum
#89217 4x14mm FHCS
#89503 RC8.2e FT Motor Mount Washers
#89529 RC8.2e FT Motor Mount Set
#89539 RC8.2 Rear Tower, Aluminum
#25192 3x20mm SHCS
#89487 RC8B RR Swaybar, 2.5 (Green) - Kit
#89530 RC8.2 FR Swaybar Kit
#89531 RC8.2 RR Swaybar Kit
#89536 RC8.2 Swaybar Pivot Ball
#89537 RC8.2 Swaybar Drop Link
#25204 3x16mm FHCS
#89304 JC Illuzion Wing (Black)
#89540 RC8.2 Wing Mount, Set
#89476 FT RC8B +3mm Chassis
#89552 RC8.2 Side Guards, Set
#89218 3x8mm Washer
#89223 3x8mm SHCS
#89454 3x12mm SHCS
#89224 3x16mm SHCS
#89227 3x28mm SHCS
#89217 4x14mm FHCS
#25192 3x20mm SHCS
#25204 3x16mm FHCS
Wow! Thanks was looking for this!
Haha, no problem! Im sure a lot of people were looking for this...I decided to take the time to do it for myself because I was curious also. Most of the parts are Factory Team and seems like it would be worth the money to go ahead and do the conversion over to the RC8.2e but it might be around $250 or so...I only priced out a couple of the parts and I was sitting around $150, but I was also using TowerHobbies as my main searching website, and didn't use any other stores/websites! Thanks for the positive feedback ! I really appreciate it!
Is there anybody else who is finding this post helpful? Please leave a post and let us know what you think of it!!
Yeah i would think too that it might be their setup or their personal opinion of the car...i have heard that its lighter and from what i have seen from the parts it is built stronger...they really thought about weight and im sure it would be worth it to convert this vehicle if you have the money to throw at it...or slowly buy the parts and put them on the vehicle until u would have to buy the chassis and probably the drive shaft +3mm when you need to do that! Other than that...battery tray and diffs are the same...no changes made...i am happy that they made a new wing and have the jconcepts body on there...cause it did make a difference in my book! I would look for some setup sheets from the pros and see what to do then!! Thanks for posting !
handy to know what parts it uses, although i cant seem to find the motor mount 89529, where did u find it? im hoping it fits on my sc8e, any ideas if it does or doesn't?
That stuff i wouldnt know about...but I have had both manuals side by side me when I was going through them...i might have forgotten that part, but you can check in the manuals if you want to. Sorry I dont know about that one dude :P
I have a Tekno V4 RC8 conversion. I was checking on updating just the suspension to 8.2 spec and well...
I was at 373.18 . That was with shocks, springs, towers, A,B,C, and, D plates, upper and lower arms, caster blocks, sway bars, wing mount and wing.
Ill just go but the whole buggy for less than $100 more and sell the one I got!
Parts I had added:
ASC89540 - Team Associated Wing Mount (RC8.2)
ASC89304 - Team Associated "Illuzion" 1/8th Scale Wing (Black)
ASC89551 - Team Associated Rear Arm Set (RC8.2)
ASC89550 - Team Associated Front Arm Set (RC8.2)
ASC89549 - Team Associated Front Upper Arm Set (RC8.2)
ASC89530 - Team Associated Front Swaybar Kit (RC8.2)
ASC89531 - Team Associated Rear Swaybar Kit (RC8.2)
ASC89558 - Team Associated Caster Block Set (RC8.2)
ASC89539 - Team Associated Aluminum Rear Shock Tower (RC8.2)
ASC89538 - Team Associated Aluminum Front Shock Tower (RC8.2)
ASC89541 - Team Associated Front Shock Spring Kit (6) (RC8.2)
ASC89545 - Team Associated Rear Shock Spring Kit (RC8.2)
ASC89290 - Team Associated Factory Team 29mm Big Bore Front Shock Kit
ASC89346 - Team Associated Factory Team 38mm Big Bore Rear Shock Kit
ASC89460 - Team Associated Suspension A-plate
ASC89481 - Team Associated "Low B" Suspension Plate w/Inserts
ASC89462 - Team Associated Suspension C-plate
ASC89463 - Team Associated Suspension D-plate w/Pins
Parts I had added:
That's a very useful list. I can speak from experience that the 8.2 parts make the car MUCH easier to drive, especially on rough tracks or crooked jump landings.
I got to run my car on a very small indoor track last weekend. First weekend on all the 8.2 suspension parts, and the car was lights-out fast. Huge improvement over the B car!
so has anyone figured out if its better to just buy the kit or is it cheaper to convert from 8be to 82.e?
Parts I had added:
Parts I had added:
