RC10B4.1 FT/WC
Old 07-17-2012 | 05:56 PM
  #16771
Wildcat1971's Avatar
Tech Prophet
Here is the interesting part. They made the front conversion supplied the hexes for the rear, made wheels for the front, but just left the rear wheels for other to make. In fact they said go use losi 22 wheels, lol. Kinda funny. It was like an 80% effort.
Wildcat1971 is offline
Old 07-17-2012 | 06:19 PM
  #16772
I need the web address for factory one products
dougwalter911 is offline
Old 07-17-2012 | 06:22 PM
  #16773
google can be your friend
PFKAOG is offline
Old 07-17-2012 | 06:23 PM
  #16774
I tried that it's not coming up with the site
Old 07-17-2012 | 08:03 PM
  #16775
http://bit.ly/Lxp7Fs
Jeckler is offline
Old 07-17-2012 | 08:22 PM
  #16776
ilanstylz's Avatar
You mean this site:
http://www.factoryone-rc.com/
ilanstylz is offline
Old 07-17-2012 | 08:33 PM
  #16777
Thank you. When I googled factory one Rc it come up with everything but that
Old 07-17-2012 | 08:36 PM
  #16778
ilanstylz's Avatar
Your welcome to me its better to help then to be a smarta** sometimes........
Old 07-17-2012 | 09:31 PM
  #16779
jf+'s Avatar
jf+
It's than, not... oh. Sorry. I thought I was still posting on that awesome FS/FT thread.
I miss that thread already.
jf+ is offline
Old 07-17-2012 | 09:43 PM
  #16780
ilanstylz's Avatar
At least you were able to find humor in my post.......
Old 07-17-2012 | 09:46 PM
  #16781
CraigMBA's Avatar
Originally Posted by Jeckler
Nice hand, well played sir.
CraigMBA is offline
Old 07-17-2012 | 11:34 PM
  #16782
Tongue in cheek of course.
At least I haven't gotten a nasty PM like the last time I did it.
Side note, why isn't there a Let Me Yahoo That For You?
Jeckler is offline
Old 07-18-2012 | 06:22 AM
  #16783
derekbsmith's Avatar
Originally Posted by kdub
Hex adapters on buggy...a few good things:
-front tires don't have bearings in the wheels
-you can put front tires on the back to break them in (typically on the street)
-Rear wheel/tire shared between TLR22, B4.1, and RB5 = all 3 major brands
-Front wheel shared between B4.1 and RB5
-Reduces broken wheel pins, and no wheel pins to fall out
I personally don't re-use wheels so I don't mind switching over. I only keep 1-2 pairs of each tire tread/compound and every time I mount new ones of the same tread, I throw away my oldest set.
I have hex only in the rear and only use hex during the winter months since all my clay wheels+tires are hex. Summer months I use pins and I do have bearings up front.
derekbsmith is offline
Old 07-18-2012 | 07:36 AM
  #16784
I am currently using 1 degree hubs in the rear and I keep seeing everyone using 0 degree ones, for what conditions are 0 degrees better?
I would assume for high traction where you want less rear grip?
here I am always looking for more rear traction. going to start to go up in shock weight in the front and shorten the camber link
opinions?
jdeadman is offline
Old 07-18-2012 | 07:42 AM
  #16785
Tech Prophet
you should not have to work that hard to get a b4 to hook up in the rear. Remember 90% of the setup is tires, if you have the wrong or worn out tires, you can wrench till the cows come home and it will never be right. No amount of wrenching will ever make up for tires. So when you ask about how to get more rear traction, the assumption is normally that you have the best tires for your track/application and you don't slam the throttle as you enter or exit the turn.
I was trying to use the .5 hubs because i thought i wanted to square up quicker coming out of the corner, so i could get on it sooner, but it only made me rotate less in the middle of the turn and i didnt like it at all.
Can you describe the tires and track/driving conditions you are dealing with?
