RC10B4.1 FT/WC
Old 02-27-2011 | 08:19 PM
  #1771
Some springs are better than others. The greens I had nedded a lot but the silvers i just got needed nothing
DG Designs is offline
Old 02-27-2011 | 08:23 PM
  #1772
So is there a way to get them to stop rubbing? Maybe some way to remove the paint so they have a little extra room?
gguertin145 is offline
Old 02-27-2011 | 08:33 PM
  #1773
FantomLeopard's Avatar
Well, I would think that the shocks bending in one or another direction as the shock compresses is because there is more contact or support on one or another side. So as stated, trying to even out the sides with a dremel might be the best way to fix this.
FantomLeopard is offline
Old 02-27-2011 | 08:51 PM
  #1774
Trust me what i said works. I did it last weekend and they are now butta. You will end up grinding off a good portion of where it overlaps.
Old 02-27-2011 | 09:34 PM
  #1775
so your grinding where the spring overlaps? I cant get you to post a picture can I?
Old 02-27-2011 | 10:15 PM
  #1776
aeRayls's Avatar
Originally Posted by 1Fastpede
Try this
aeRayls is offline
Old 02-28-2011 | 06:01 AM
  #1777
Muggydude's Avatar
Just want some clarification. On the Proline Bulldog body for the b4.1, they made a running change to the design of the body. This means the new ones have the same part numbers, right? And they are already in circulation? Does anyone know when the change was made?
Muggydude is offline
Old 02-28-2011 | 11:56 AM
  #1778
UltegraSTI's Avatar
Picked up a 4.1 kit yesterday. all these yrs of used b4s just wanted to sit down and build 1 new outta the box.
Well a few things i find less than 'associated'.
1st. The known quantity of the weak chassis issue up at the 'chin'. AEs remedy for this problem (til the present stock of chassis run out i guess) is to use a carbon bulkhead to strengthen it. i did, we'll see how it goes.
2nd. Battery posts alignment where the all thread goes thru for the nuts to spin on. i had to run them in point just slightly outward and massage the holes in the strap, ovalizing them just a bit for the spin nuts to seat correctly.
3rd. NO Rear Wheelnuts? You serious!
4th. The new ball cups, well i'm not goin to use them as i've seen how rubbish they truely are since most every1 got a 4.1 before i did. older or RPM units for me.
5th. Rear T-Plate angle in back leaves huge gap in between itself and tranny such that when u place tranny in the rear u think u've done somethin wrong. relying on those 2 rear screws for the motor guard to pull everything flush is not right at all.
6th. Clunky CVAs. 1 unit was fine, however the 2nd was horrid after i tightened the setscrew. loosen it and it was fine. tried other side of barrel in the cva. same result. had to use some cutting oil and fine abrasive to slightly work in the unit, then it was gravy. perhaps something that works itself right in 1st run or 2, still off putting.
7th. You give me stealth lube and black grease, but no green slime or loctite blister pack?
8th. New tranny case and thicker motor plate, but same size tranny screws. cant use washers unless u want ur motor plate come loose. New tranny case also has interference w/AE Zinc block weight made for the car.
9th. other kits have their bellcrank spring already preset/prethreaded. very easy task to kill the threads in the 1st step of the kit. i didnt due to experience, but others might might cry in their beer or their milk at step 1.
10th. Oh yeah, the thicker motor plate makes standard 3x2.5mm motor screws not work or on ragged edge of grasping the motor. i'm sure some folks are stripping threads innocently gettin those nice new 85$ motors in and the screws can hold it or tear 1st thread out b/c thats all they are holding.
Fix these issues on 2nd run.....or just put the b5 out already and end the speculation and endless banter on the internet.
R
UltegraSTI is offline
Old 02-28-2011 | 12:08 PM
  #1779
Jowers's Avatar
1st. The known quantity of the weak chassis issue up at the 'chin'. AEs remedy for this problem (til the present stock of chassis run out i guess) is to use a carbon bulkhead to strengthen it. i did, we'll see how it goes. Where do you get a carbon bulkhead from? Also, they slightly reinforced this area compared to the B4.. look and compare
3rd. NO Rear Wheelnuts? You serious!I believe it... my T4.1 only came with 11 diff ball... called AE and the guy told me "it should be fine."
4th. The new ball cups, well i'm not goin to use them as i've seen how rubbish they truely are since most every1 got a 4.1 before i did. older or RPM units for me. Losi whites for me... they look so nice and strong as hell!
6th. Clunky CVAs. 1 unit was fine, however the 2nd was horrid after i tightened the setscrew. loosen it and it was fine. tried other side of barrel in the cva. same result. had to use some cutting oil and fine abrasive to slightly work in the unit, then it was gravy. perhaps something that works itself right in 1st run or 2, still off putting. Don't need the set screws thats what the retainer clips are for.. less binding
7th. You give me stealth lube and black grease, but no green slime or loctite blister pack? +1
8th. New tranny case and thicker motor plate, but same size tranny screws. cant use washers unless u want ur motor plate come loose. New tranny case also has interference w/AE Zinc block weight made for the car. I still run the old motor plates to assist with motor offset.. FT Lipo ballast fits fine in my B4.1...
10th. Oh yeah, the thicker motor plate makes standard 3x2.5mm motor screws not work or on ragged edge of grasping the motor. i'm sure some folks are stripping threads innocently gettin those nice new 85$ motors in and the screws can hold it or tear 1st thread out b/c thats all they are holding. Again, just use an old motor plate if its a problem... shouldn't be though.
Fix these issues on 2nd run.....or just put the b5 out already and end the speculation and endless banter on the internet. YES! +1,000,000
R
Bring on the B5! I heard Wild Cherry has one already...
Jowers is offline
Old 02-28-2011 | 12:36 PM
  #1780
Originally Posted by aeRayls
Try this
This worked great thanks!
Old 02-28-2011 | 01:10 PM
  #1781
Default spur gear/pinoin combo
Trying to gear a 17.5 in a b4.1 What is the largest pinion I can run with a 75 and or a 72 spur gear without runing out of gear mesh adjustment?? I am currentely running a 72 spur/ 30 pinoin and it is temping at 85 deg.
rcdog008 is offline
Old 02-28-2011 | 01:22 PM
  #1782
Pete Martinez's Avatar
R
all you do is cry bitch and moan on every thread whats up your butt
and never seen you any big race whats up with that.
Pete Martinez is offline
Old 02-28-2011 | 02:10 PM
  #1783
Jowers's Avatar
Sounds about right... but it depends on the motor/esc as well
I run 27/78 with SXX/Tekin 13.5 temps ~140*
If I was to try and gear for 17.5 I would go up 4-5 on pinion and 75 spur
Jowers is offline
Old 02-28-2011 | 02:14 PM
  #1784
1Fastpede's Avatar
racers..
how much rebound do you guys put in the rear shocks?
1Fastpede is offline
Old 02-28-2011 | 02:18 PM
  #1785
Jowers's Avatar
racers..
1-2 mm hard rebound
Jowers is offline
