Like Tree5Likes
SC10 4x4 Thread
Old 07-08-2012 | 06:06 PM
  #26221
Jake S's Avatar
Originally Posted by SloMoFo
Can someone post or PM the pics of this 8mm mod?
used google and found some different images...
Jake S is offline
Old 07-08-2012 | 06:31 PM
  #26222
Wildcat1971's Avatar
Tech Prophet
Meh, bad day at the track. truck seemed better, but I think I blew my sensor board. The motor wont turn over with the sensor cable plugged in. Tried 3 different cables. Other stock motors worked fine.
Wildcat1971 is offline
Old 07-08-2012 | 06:41 PM
  #26223
Shark413's Avatar
That's my truck over on RCShortCourse. I have a few more pictures, any specific area you looking for?
I am running the B44 CF extension with the stock hubs reversed which puts the camber links in a straight line.
Shark413 is offline
Old 07-08-2012 | 06:47 PM
  #26224
Tech Prophet
I thought they looked backwards, I was wondering. So your swapped them to keep them more in line. Are the hubs zero degree?
Old 07-08-2012 | 06:49 PM
  #26225
Are there any Cliff Notes for all the upgraded parts that work? I have searched for the FT upgrade conversion as well as some other stuff and I am coming up empty for a solid direction. 1750 pages is a LOT to try and sift thru and the front page doesn't look like its been updated in a year!
I have seen things about the 8mm mod, different center diffs, FT upgrade, dual stage pistons... I just don't know which way to go with this stuff.
mustang347 is offline
Old 07-08-2012 | 07:03 PM
  #26226
drolmaeye's Avatar
The problem is that the thread "owner" is no longer an SC10 4x4 person, so there is no one that can/chooses to update a simple, single place (e.g. the first post) with developments. I really think it may be time for someone to start a "part 2" thread (as was done with the SC10 thread, for different reasons) and properly put together a first post. I can think of a few good candidates (and a few poor candidates) to undertake the task.
drolmaeye is offline
Old 07-08-2012 | 07:45 PM
  #26227
smanders's Avatar
Diff Issues.....
So I was having the notorious front diff clicking under braking and acceleration. So I pulled apart the front diff and order all the parts to rebuild it. I put in 7k fluid and just finished putting it together. Before putting the diff back in the gearbox, I held the diff and spun one of the drive cups. The diff gears move but they seem to bind a bit. Then sometimes it completely binds until I actually nudge the other free drive cup. So in the end, I think I would still have the same problem as before. Why is my front diff binding? I tried loosening the 4 screws that holds the diff together. I was wondering if I had them too tight? However, it did not help. Any suggestions?
Thanks,
smanders
smanders is offline
Old 07-08-2012 | 07:52 PM
  #26228
Originally Posted by smanders
Diff Issues.....
Thanks,
smanders
are you sure the clicking you heard wasnt from the belt ?
you also could of over shimmed the diff or it could be some dirt in there getting stuck in between the teeth.
the easiest thing to do is tear it back apart and check for and dirt,also check for any bad teeth on the gears. if everything looks good, put it back together DRY. if it still does it take out one shim from both sides (depending on how many you have in there). then put it back together dry again and check.
keep repeating process till you find out what it is.
twisted is offline
Old 07-08-2012 | 08:11 PM
  #26229
Maddog94's Avatar
Forgive me for 2 things:
First, forgive me if this question is dumb.
Second, forgive me if this question has been asked/answered before.
If you were to use both 19T belt pullies, would it effectively act like increasing the pinion gear size? Just curious basically.
Maddog94 is offline
Old 07-08-2012 | 08:21 PM
  #26230
smanders's Avatar
I'm just running the stock configuration. One shim on each side between the pin and the larger gasket.
I'll double check the teeth. Thanks for the advice!
smanders is offline
Old 07-08-2012 | 08:24 PM
  #26231
racerob1983's Avatar
Default Sellout
Hey guys selling my truck have ton of brand new spare parts over 350.00 retail make me offer [email protected]
racerob1983 is offline
Old 07-08-2012 | 08:27 PM
  #26232
Tech Prophet
I tried the over drive gear in the front and it was fail. I tightened the tensioners all the way and I still had belt skip. So 2x 19 would prob not work.
Old 07-08-2012 | 08:33 PM
  #26233
im not 100% sure but i think it tells you not to do that in the manual.
twisted is offline
Old 07-08-2012 | 09:50 PM
  #26234
BDK74's Avatar
Diff Issues.....
I had a similar problem after rebuilding mine. I found that the washers behind the small gears (planet gears) on the crossing shafts were too thick. This caused the planet gears to be squeezed inward too far and cause serious binding. I left the washers out and compensated by adding washers behind the sun gears. So far so good
BDK74 is offline
Old 07-08-2012 | 09:54 PM
  #26235
Jake S's Avatar
cannot make a decision between the PL Tundra or the JC Hi-Flow...
anyone else drive both?
Jake S is offline
