Team Associated TC6 Thread >
Like Tree20Likes
Old 07-06-2012, 10:29 AM
  #7096
Yes. I didnt like it on a bumby track. Indoor it was quite good.
dennisV is offline
Old 07-06-2012, 02:11 PM
  #7097
Trader Rating: 86 (100%+)
thanks sabastein. i will have to try it out
Originally Posted by S_fender
Personnally i like to use
Long inner camber link hole
- On carpet track (but not always true... test-test-test)
- On long outside tracks with fast sweepers.
It gives fastest directions changes with better stability.
Short inner camber link hole
- On short outside tracks with lot of "slow" turn.
It gives better stability in that case.
Long/Short balstud is used to find the correct height with little change.
Shims under ball stud to use ? :
When using more shims under ballstud (inside and outside), the parallelepiped (Camber link + arms) is bigger and means better stability.
Difference betwwen outside and inner balstud : The more the camber link is angled
"how would i know is my droop or camber is too little or too much?"
Droop => testing is the best ?
Camber => See your tyres wear.
See the manual,all is explained :
Camber Link Position:
The camber link is used to set static camber at ride height, but it is also an effective setting to adjust roll center height and camber
gain. The TC6.1 has 7 positions for the front camber link, and 14 for the rear. These positions vary in both length and angle.
Longer links will produce less camber gain, stiffening that particular end of the car in roll. These are particularly effective on large
tracks with big sweeping corners. Shorter links will give more camber gain, softening that end of the car in roll. This will make the
car more aggressive, and is a good setting for smaller indoor tracks with high grip levels.
The angle of the camber link will make fine adjustments to the roll center height. Typically the camber link will be no more than
parallel to the suspension arm with the inboard side of the link lower than the outboard side. As the inboard side of the camber link
is moved down, the roll center goes up, stiffening that end of the car. Camber link angle is a good adjustment to help fine tune the
balance of the car to the track by setting the front and rear at slightly different angles.
Sébastien
littlealex is offline
Old 07-07-2012, 06:05 AM
  #7098
Monsta's Avatar
Originally Posted by Rick Hohwart
The fact that the ball stud is vertical means nothing. But mounting it vertically allows you to make finer adjustments to the height of the ball which you may or may not find works better.
It is definitely a good tuning option.
Thanks for the reply rick. I'll give them a go
Monsta is offline
Old 07-07-2012, 11:02 PM
  #7099
gom
can anyone tell me if the tc6.1 steering knuckles work with the tc6 c-hub and lower arms? i have a tc6 and i want to give the 6.1 steering knuckles a try. i heard they have more steering?
gom is offline
Old 07-08-2012, 05:48 AM
  #7100
They would probably fit, but the bearing sizes are different, so you'd have to use TC6 axles.
Kevin Marcy is offline
Old 07-08-2012, 07:52 AM
  #7101
racer x 1's Avatar
Trader Rating: 27 (100%+)
charge your dremel. the .1 castor block has to be massaged in but it will work.
racer x 1 is offline
Old 07-08-2012, 08:47 AM
  #7102
gom
got it. thanks guys.
gom is offline
Old 07-08-2012, 09:48 AM
  #7103
vito's Avatar
will a mamba max pro esc and 4 pole 5700 motor be a fun setup.
vito is offline
Old 07-08-2012, 12:07 PM
  #7104
Yes. If it fits your needs.
If you race at a track, check what the locals are running.
dennisV is offline
Old 07-08-2012, 12:13 PM
  #7105
vito's Avatar
i dont race just need to go fast
vito is offline
Old 07-08-2012, 06:07 PM
  #7106
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Any of you guys going to the USVTA nats in sep
Just want to see how many are making the trip
With TC 6/6.1
Maybe we can get som help from each other
You know us non team drivers need to help ourselves
rcpaintinpete is offline
Old 07-09-2012, 06:41 AM
  #7107
With TC 6/6.1
I'll be going. Just picked up a 6.1. I'll have plenty of time to get it dialed in at The Gate before the Southern Nats. WE are having a Vegas Warmup the weekend before and several club races before that.
chuck
mackin is offline
Old 07-09-2012, 07:04 AM
  #7108
Hey everyone, I was looking at some AE team driver setup sheets and noticed some Note that the steering blocks are "reversed". Does this mean the blocks are flipped upside down and switched? I.E The right block is now used as the left block and vise versa?
Thanks.
Biggie85 is offline
Old 07-09-2012, 07:35 AM
  #7109
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
i know its not the right forum, but if anyone is thinking of getting rid of their tc6-6.1 please let me know. i would like to trade my like new losi 8e as long as they are equal in shape and parts. i currently have already a tc6 but want another one for gt3 or vta, thanks.
Mr.juarez is offline
Old 07-09-2012, 12:25 PM
  #7110
justchris's Avatar
Thanks.
Yes dead right
justchris is offline
