Like Tree1Likes
B44.1 Thread
Old 07-05-2012 | 09:57 AM
  #2431
JEFFs SC10's Avatar
Oh I didn't know it was t4, sorry.
JEFFs SC10 is offline
Old 07-05-2012 | 03:42 PM
  #2432
symmetricon's Avatar
Ok, so no response to my last post, so let me ask this. Should the front be noticeably less dmpened than the rear of the buggy, since I have no idea what pistons are in the front stock v2 shocks and the rear powerstroke shocks? I have 35wt losi in the front and it feels real soft while the rear has 250cst oil i it and it feels much more dampened. What do you guys think or know ????????
symmetricon is offline
Old 07-05-2012 | 05:28 PM
  #2433
rigor's Avatar
No the front shocks should feel about the same as the rear and pretty balanced overall (front & back). You could always just check if those ProLine rear shocks would accept the standard AE pistons in them and purchase them. You really really want to know the answers to any suspension setup questions regarding your car, so you can further dial it in more as needed.
I hope your car turns out to be ok; I'd be weary that you didn't get the AE v2 rear shocks and that there was grass clippings throughout the car
rigor is offline
Old 07-05-2012 | 06:57 PM
  #2434
Thanks for the reply,
the proline shocks are a larger diamiter bore than the stockers.... I guess if anyting I can drill them out since I have a an assortment of metric drill bits. as for the car, I did a rebuild to check everything out, the diffs and the ring nd pinion gears looked to be in perfect shape, and the balls and ring were in almost in new shape. It doesnt even have a single scratch on the shock towers, the chassis protector, body, wing or even the bumper, heck the motor doesnt even have a scratch.
Ok, so how about this, how far of a drop (bench test) should it take to bottom out?
Old 07-05-2012 | 07:38 PM
  #2435
rigor's Avatar
Drop from about 6" and the front should be at 21mm, and the rear 20mm.
rigor is offline
Old 07-06-2012 | 05:17 AM
  #2436
Thanks again, I think I have the shocks pretty close, but I will see soon when it takes its maiden voyage this afternoon.
I aslo wanted to comment the quality of the b44.1, it is top notch, the plastic, screws and carbon fibre seem to be made in a different place than some of the other associated rc's that i have owned, and not that they have been bad either, but this is one of the nicest, well thought out, easy to work on, no nonsense no compramise to racing rc's that i have everput my hands on. Bravo AE
Old 07-07-2012 | 11:43 PM
  #2437
Originally Posted by jay m
i was wondering if someone can give me a starting setup b44.1 hw120 esc 10.5 sp motor medium size track some of the other guys are runing 8.5 turns but i know the 10.5 can match the speed with out being so aggressive down low need pinion size help and speedy program setting to start from cheers just getting back into racing from a short break
can any1 point me in the right direction
jay m is offline
Old 07-08-2012 | 12:06 AM
  #2438
rigor's Avatar
I can tell you that I run a 6.5 in my B44.1, and I run the 81 spur with a 19 pinion. You could probably start at a 21 pinion and go from there. Be sure to check with a temp gun after running for 5 minutes.
rigor is offline
Old 07-08-2012 | 01:09 AM
  #2439
whats the biggest spur gear to fit b44.1 cheers
jay m is offline
Old 07-08-2012 | 03:41 AM
  #2440
20 SMOKE's Avatar
ran mine last night,this is the first time in 4yrs in a 4wd,tq and win dam i have missed this thing.
10.5 motor will be around a 23-81,like said above a 6.5 is around a 18ish.
jay n,what are you trying to do
20 SMOKE is offline
Old 07-09-2012 | 01:38 AM
  #2441
just want to see if i can get the 10.5 to keep up with some of the guys that are using 8.5. most of my racing has been on road and not sure if my esc settings will be any good off road may produce higher motor temps. and not sure the car can handle a 4.5 got no motors in between atm but im sure the 10.5 with some boost can keep up.
jay m is offline
Old 07-09-2012 | 03:34 AM
  #2442
crashnburn's Avatar
I have a LRP 8.5 in very good condition that I would be willing to let go for a decent price. If you are interested, just send me a PM.
crashnburn is offline
Old 07-09-2012 | 03:49 AM
  #2443
20 SMOKE's Avatar
what esc and size of the track
20 SMOKE is offline
Old 07-09-2012 | 04:58 AM
  #2444
esc, hw v2.1 120 amp
track, medium technical loose 40 meter straight
thanks.
jay m is offline
Old 07-09-2012 | 08:34 PM
  #2445
Mini8 Menace's Avatar
Default Get a 6.5
Get a 6.5 trust me just grab the controller and coolest crowd you'll love it you can always dial it down and get the LRP tc esc I was in the same boat you were in and they told me to go to a 6.5 I was kind of hesitant at first but I went with it anyway and trust me it was the best decision for the car I currently run on eight scale track with 18/81 gearing but when I run on a 10 scale track I just dial it down a bit and it's ready to go full throttle and everything
Mini8 Menace is offline
