Like Tree5Likes
SC10 4x4 Thread
Old 06-24-2012 | 02:26 PM
  #25561
kjohnsiii's Avatar
Originally Posted by umpy907
Has anyone been runnin the heavier center chassis? If so any thoughts on how it works?
I have, it works awesome too
kjohnsiii is offline
Old 06-24-2012 | 04:16 PM
  #25562
Kjohnsiii your funny I'm buying yours I just wanted to see what other people thought about it :-)
umpy907 is offline
Old 06-24-2012 | 05:13 PM
  #25563
GreenSC10's Avatar
Default Bearings
Check the link for sweet bearing kits by Boca Bearings for the SC10 4x4 smoother roll means less friction and equals reduced heat and faster lap times!!!
http://www.bocabearings.com/search.a...TRUCK&Feature=
GreenSC10 is offline
Old 06-24-2012 | 05:21 PM
  #25564
ABN Hoosier's Avatar
quick question...I have the "Mac the Knife" clutch basket installed and think it works great. Is there any difference/advantage to the new VTS Slipper Conversion from AE in comparison?
ABN Hoosier is offline
Old 06-24-2012 | 05:24 PM
  #25565
Wildcat1971's Avatar
Tech Prophet
Originally Posted by twisted
i dont have a pair of calipers so can someone convert the sizes of the sway bars to the corresponding colors that they are giving with the heat shrink ?
yellow 2.2
blue 2.0
the other one is 1.8, I forget the collor
Wildcat1971 is offline
Old 06-24-2012 | 05:26 PM
  #25566
CraigMBA's Avatar
No. Functionally they are exactly the same. They even weigh the same as an assembly, to the gram.
You can't use the MTK basket on a 2w. The vts is an awesome upgrade there.
CraigMBA is offline
Old 06-24-2012 | 05:29 PM
  #25567
GreenSC10's Avatar
I google'd it and didn't see the MTK, where did you get it?
Old 06-24-2012 | 05:32 PM
  #25568
Thank you.
Also, can you tell me, or direct me to some info on the "pinned top shaft"? I don't have that Mod yet. Oh, and also any info on shock improvements? I got some $ in my piggy bank and want to juice up my SC10 4X4 this month.. Thanks
Old 06-24-2012 | 05:39 PM
  #25569
For pinned shaft, you will need new design rear topshaft and AE coupled inner slipper hub. New Exotek inner drive hub seems to be a better choice though according to what I have seen.
JLinney is offline
Old 06-24-2012 | 05:40 PM
  #25570
http://www.rctech.net/forum/r-c-item...ch-basket.html
Old 06-24-2012 | 05:41 PM
  #25571
got some part numbers or links Hoosier?
Old 06-24-2012 | 05:42 PM
  #25572
CraigMBA's Avatar
Thank you.
You have some options.
The FT top shaft has been changed, and you can buy a slipper plate from AE that will get it done.
Exotec makes a locked plate that replaces the front slipper plate and inner slipper pad, yet let's you retain the slipper for the rear. I have one, it's on, but I haven't run in a month.
CraigMBA is offline
Old 06-24-2012 | 05:57 PM
  #25573
ilanstylz's Avatar
Here is the link to the exotek inner slipper hub:
http://www.exotekracing.com/sc10-4x4...-front-clutch/
It replaces the inner stock hub as well as the inner stock slipper pad and locks the front. I've had mine for awhile now and to me its one of the best mods (yeah I admit I was skeptical at first) for the sc10 and its cheap.
ilanstylz is offline
Old 06-24-2012 | 06:06 PM
  #25574
old top shaft
http://www.amainhobbies.com/product_...Rear-Top-Shaft
new top shaft
http://www.amainhobbies.com/product_...-Rear-Topshaft
I am not clear on what the difference is. I am kinda confused. I have the MTK clutch basket. Would the new Top shaft help? Is the new TS pinned? Should I junk everything and get the $8 exotech clutch? Weird they call it a front clutch. Is that because it's on the outside, kinda like on the top.
Old 06-24-2012 | 06:20 PM
  #25575
CraigMBA's Avatar
Just get the clutch.
CraigMBA is offline
