Like Tree5Likes
SC10 4x4 Thread
Old 06-22-2012 | 12:06 PM
  #25456
Wildcat1971's Avatar
Tech Prophet
Originally Posted by samuelsonmark71
I put mine in the shock boot
I tried that, but the boot was catching on the limiters and removing /adding limiters is more of a pain. Above the cup and under the bumper allows you to add or remove the limiters with the shocks mounted. From what I have read you want 8m TOTAL, count the boots and bumper. Calculating the thickness of the compressed boot was terrible so I just added limiters until I felt there were enough space. Which for mew was 4mm limiters + 3mm bumper and boots on front. And 2mm limiter, 3mm bumper and boots rear. Fully compress your shock and check to see if the cvd is close to hitting the drive cup. If it is, add another 1mm until you have the space you need.
I used the ones that came with the kit. The 1mm clips seemed a little unstable to me and didn't grip as well as the 2mm clips, so i didn't use any 1mm clips. I think the shaft is 4mm, at least it seemed like that when i put calipers on it. So you want to get closed off limiters get 4mm inside diameter.
Wildcat1971 is offline
Old 06-22-2012 | 12:10 PM
  #25457
Wild Cherry's Avatar
Originally Posted by ilanstylz
So how many limiters is everyone putting on their front and rear shocks and are you using the stock ones that come with the kit or are there better ones out there?
Been using 3 B-4 shock pistons for external shims ...
Wild Cherry is offline
Old 06-22-2012 | 12:11 PM
  #25458
Tech Prophet
I seems like 7-8 mm total limiting are what most setups use. 8mm is the generic answer.
Old 06-22-2012 | 12:12 PM
  #25459
Tech Prophet
Did you bore them out? Those are 3mm inside diameter , no?
  #25460
Cain's Avatar
Originally Posted by darryl80
I put 5mm on each shock would it hurt to put another 1mm on each shock to use up the rest of my limiters?
I doubt having more than the minimum limiters needed is going to hurt anything.
Cain is offline
  #25461
ilanstylz's Avatar
Can someone post pics of their front/rear shock limiters placement? ;-)
ilanstylz is offline
Old 06-22-2012 | 12:21 PM
  #25462
Jake S's Avatar
my limiters
my rear weight added... 4 blocks on each side in shrink tube for that cleanish look
and my b4 plastic hub 8mm mod on my dirty truck that i didnt clean after practice hah
Jake S is offline
Old 06-22-2012 | 12:24 PM
  #25463
Yeah , you have to drill the piston to use , can use anything almost to shim .
personally like the pistons ,use a sharpie on the pistons for a cleaner look
Old 06-22-2012 | 12:30 PM
  #25464
t0p_sh0tta's Avatar
Jake, is that fuel tubing?
t0p_sh0tta is offline
Old 06-22-2012 | 12:34 PM
  #25465
Jake S's Avatar
yes it is, but its autozone tube so its stiffer then rc fuel tube hah
Jake S is offline
Old 06-22-2012 | 12:54 PM
  #25466
Jake S's Avatar
most likely going to switch to washers from LHS (local hardware store lol) so i can adjust from 6mm-9mm range so i dont have to adjust with a hobby knife hah.
and i believe their nylon washers are black too
Jake S is offline
Old 06-22-2012 | 02:46 PM
  #25467
why not just use the small limiter clips that come with the kit for the shocks ?
twisted is offline
Old 06-22-2012 | 02:52 PM
  #25468
Tech Prophet
you can. but they are clips. and clips can pop off. I just put mine on 2 nights ago, not sure if they will stay on or not.
Old 06-22-2012 | 02:56 PM
  #25469
I never lost a clip, had them on there for a good while already. They hold on tightly.
Arakon is offline
Old 06-22-2012 | 03:01 PM
  #25470
SOuthernFRIED's Avatar
Yea, had my clips on a while and they've survived some truly noteworthy crashes.. Haven't lost one yet!
SOuthernFRIED is offline
