Like Tree5Likes
SC10 4x4 Thread
Old 06-19-2012 | 05:28 PM
  #25276
dirtbikekid33's Avatar
nope my a arms are just as old as the cva's. I ran the old ones for 6 mos with no shock limiters and fixed that back when it was first posted in here.
dirtbikekid33 is offline
Old 06-19-2012 | 05:32 PM
  #25277
CraigMBA's Avatar
Hope you figure it out then.
CraigMBA is offline
Old 06-19-2012 | 07:33 PM
  #25278
SCTDan's Avatar
Originally Posted by Evil Genius jr.
Thinking off selling my SC10 4x4, I want to try a different class and can only afford one car at a time . Has the following:
Custom saddle pack conversion
Custom chassis brace
8mm mod
RCShox 2-stage pistons
RCshox V2 Center diff
Trackstar O-rings
Sway Bars
Aluminum hexes
RPM Front Arms
STRC Aluminum belt tensioners
A bunch of extras and brand new avid hub bearings.
Diffs correctly shimmed
2 sets of wheels
2 sets of mounted AKA city blocks (one 60%, the other brand new)
2 beat up bodies
2 slightly puffed (still balance and work perfectly) Gens Ace 6000mah 25C saddles
Any idea how much I could get?
Thanks! Hopefully I can stay but I want to try something else with a wing lol.
Ya right! I think the new DESC410 V2 comes with a wing Is that why you've been lurking on the Rango forum
SCTDan is offline
Old 06-19-2012 | 07:35 PM
  #25279
Wildcat1971's Avatar
Tech Prophet
Does AE put an overspray film on the INSIDE of the 4x4 body? Please say no.
Wildcat1971 is offline
Old 06-19-2012 | 07:49 PM
  #25280
No.
JLinney is offline
Old 06-19-2012 | 08:17 PM
  #25281
TEAM-AE-4-EVER's Avatar
Originally Posted by Grouchman
I race at Westcoast Raceway, which is 100% clay, med-high traction, indoor track. Exotek doesn't make a front system. I'm using the VTS Slipper w/Garodiscs from Marcus along with the Exotoek Inner Hubs. The Exotek inner hub removes the inner disc with a solid plate. Truck feels like the pin mod, lots of rear traction. I'm digging it right now.
Originally Posted by ilanstylz
Grouchman got it right on the dot, the exotek is only installed on the inner part of the spur with the vts going on the outside. I had great success with the v1 diff and for some reason I kept having issues with my v2, now I know its all on me because I probably didn't install it right. However with the setup I am currently running on an indoor small clay track it seems to working just as good if not better then my v1 diff. If I keep my center diff I may just install it and try it once again and compare it with my current setup but I can honestly say what I'm running now is working out great.......
Cool! Hey thanks guys for the replies and sharing the info!
TEAM-AE-4-EVER is offline
Old 06-19-2012 | 09:13 PM
  #25282
Tech Prophet
What is a "Exotek inner hub"? I dont see it on their website.
Old 06-19-2012 | 09:18 PM
  #25283
drolmaeye's Avatar
Hey, this is what they are talking about:
http://www.exotekracing.com/sc10-4x4...-front-clutch/
Edit: Just went to purchase one myself and I'm not smart enough to figure out how to buy one. I notice "Exotek" is on vacation . . . I guess I'll get it sorted when "they" get back.
drolmaeye is offline
Old 06-19-2012 | 09:20 PM
  #25284
Does this truck corner better then the Losi? Is it as tough?
I LOVE my Losi, but have seen a few of these at the track and am intrigued.
Ironwolf1974 is offline
Old 06-19-2012 | 09:26 PM
  #25285
Jake S's Avatar
https://www.ssl-stormerhobbies.com/c...=ns&pn=EXO1206
backordered on stormer too
Jake S is offline
Old 06-19-2012 | 09:35 PM
  #25286
Jake S's Avatar
what im running right now, seems really good outdoors.
just think i need alittle washer on the vst4 slipper still tho. running a HT pad on the inside too, front pulls nice with the HT pad.
Jake S is offline
Old 06-19-2012 | 10:15 PM
  #25287
Tech Prophet
8MM up travel limiters, are limiters between the body and the shock end? What does this gain you?
Old 06-19-2012 | 10:16 PM
  #25288
Cameron Kellogg's Avatar
Would be lying if I said I was not excited to see they have a V2 coming out.
Cameron Kellogg is offline
Old 06-19-2012 | 10:39 PM
  #25289
Jake S's Avatar
limits uptravel, so that the cvd/cva doesnt mess up the out drives.
i use fuel tube so its not as solid too, which is pretty trick because you can get it in like any color at a hobby shop, and normally like $2/foot, some places might give you 2" too heh
Jake S is offline
Old 06-20-2012 | 02:19 AM
  #25290
Wild Cherry's Avatar
The arms can still bend or flex on hard landings making it possible to bend CVA even with the external limiters installed .
cameron
this sway bar deal is way more than I can explain how to do .
You will need to make when you get here .
custom ft & back bar's guy ...
when you see pictures( tomorrow maybe Fri) you will understand
track pics for sure tomorrow night
Wild Cherry is offline
