SC10 4x4 Thread
Just want to make sure it's clear for those who try to emulate you; 30 degrees or the value of 30 on the timing advance slider?
While I was cleaning up my slipper, I noticed that where the belt cover goes into the tunnel shape, the belt is actually laying right on top of that at the bottom. There's some marks of it rubbing there too. It seems to be very close or even touching all along the belt tunnel. It doesn't seem to cause trouble, but that is unneeded drag.. however, there's nothing I can do to raise the belt at the bottom, or is there?
Why Tekin did that way I will never know.
Mine doesn't flex, I have four screws holding it to the chassis. Fans been there for a year.
Nope Murfdogg dyno's them I just run them. All motor manufactures have their own zero mark. With the low wind Murfdogg motors he set's mine at -5 for short course. I have not come up short yet on any jump combo or at least what is the fastest way around the track combo.
I race at Westcoast Raceway, which is 100% clay, med-high traction, indoor track. Exotek doesn't make a front system. I'm using the VTS Slipper w/Garodiscs from Marcus along with the Exotoek Inner Hubs. The Exotek inner hub removes the inner disc with a solid plate. Truck feels like the pin mod, lots of rear traction. I'm digging it right now.
Grouchman got it right on the dot, the exotek is only installed on the inner part of the spur with the vts going on the outside. I had great success with the v1 diff and for some reason I kept having issues with my v2, now I know its all on me because I probably didn't install it right. However with the setup I am currently running on an indoor small clay track it seems to working just as good if not better then my v1 diff. If I keep my center diff I may just install it and try it once again and compare it with my current setup but I can honestly say what I'm running now is working out great.......
I finally bent my kit cva and bought these ft ones and i have gone thru about only 3 packs no hard crashes and yes i have shock limits on my car. Well i have bent both already, anyone else notice this yet.
My CVAs are a year old, never bent one. six sets of A arms, YES.
5Likes
