Like Tree5Likes
SC10 4x4 Thread
Old 06-04-2012 | 09:47 AM
  #24526
vito's Avatar
love this kit a lot. i got the ft upgrade kit and i play in the street need some more top end motor is a 4.5 novak 550
vito is offline
Old 06-04-2012 | 09:48 AM
  #24527
Cain's Avatar
Originally Posted by Evil Genius jr.
Tower hobbies with member coupon.
+1
Seen a few NIB ones on ebay as well too for that price.
Probably could get a few of the smaller online shops to match that price too.
Cain is offline
Old 06-04-2012 | 10:08 AM
  #24528
SOuthernFRIED's Avatar
Use this code for tower discount 010J7 .. You'll get free shipping too
SOuthernFRIED is offline
Old 06-04-2012 | 10:11 AM
  #24529
darryl80's Avatar
i just bought a brand new sc10 4x4 factory team kit truck for $299 on ebay. i am so excited to get it and build it.
darryl80 is offline
Old 06-04-2012 | 10:19 AM
  #24530
I ordered new cva bones some days ago, and only just now realized.. the FT manual lists both front and rear CVAs as 91040, while the non-FT manual lists 91040 as front and 91041 as rear. What is the difference between the two?
Arakon is offline
Old 06-04-2012 | 10:30 AM
  #24531
ShortCourseOnly's Avatar
Originally Posted by ShortCourseOnly
OK. So I liked the Shorty pack solution and am planning installation. I baught two shorty packs and would like to use the FT saddle pack battery brace but rotated 90 degrees. Anyone have insight into this? I won't be able to do the installation until late July.
OK the Reedy Shorty packs that I bought are 94mm long and 47mm wide each. That means that they will be 94mm x 98mm in the tray. Saddle packs are 69.5mm x 47mm which results in 69.5mm x 98mm. This means that I can mount them with the short side (long side of the hardcase) across the chassis and use the stock battery strap. I wouldn't need to FT battery brace. I would have to mount the ESC where the receiver box is and the reciever can go under the strap on the slipper side. That is my plan and I hope to provide pics in July when I get to this. I would love to see some pics of peoples installations.
Secondarily the Reedy Shorty packs are 202gms each (404gm together) when my stick packs are over 300gms. The Reedy Saddle packs are 298gms. That means that I would be adding 100gms to the weight of the vehicle. I think this is great for managing front/rear balance. I plan to get this truck to 50/50 f/r weight if possible.
ShortCourseOnly is offline
Old 06-04-2012 | 11:02 AM
  #24532
Evil Genius jr.'s Avatar
So do the RPM arms actually resist warping anymore than the stock ones? My left front one is bent almost 10 degrees.
Evil Genius jr. is offline
  #24533
Cain's Avatar
Originally Posted by easye
For your shorty setup, what are you using to brace the batteries, between the ESC and batteries?
Cain is offline
Old 06-04-2012 | 11:10 AM
  #24534
Wild Cherry's Avatar
Originally Posted by Cain
Assuming the el cheapo 12mm studs work too, or do you need the more expensive ones for a durability reason there?
can use metric instead for mounting the C-tower
Can't assume everyone has 4 screws or lock nuts, metric or standard ...
only benefit to use standard thread buttons is
no need to drill the holes on C-tower
also
think the orange lock nut looks eye candy as well
Did forget one thing though ....
need 2 #31286
Wild Cherry is offline
Old 06-04-2012 | 11:19 AM
  #24535
heres the lipo with the cracked case :
the cells look good.
twisted is offline
Old 06-04-2012 | 11:30 AM
  #24536
I've been running mine since february and only today flipped them around cause they started showing signs of bending.
Arakon is offline
Old 06-04-2012 | 11:38 AM
  #24537
Resqnu's Avatar
8mm
6917 button screw
4449 lock nuts
9873 C Tower
91121 12m stud
Catching up and reading about this mod. Does everyone still like it? What exactly does this improve?
Resqnu is offline
Old 06-04-2012 | 11:43 AM
  #24538
i did this not to long ago. i felt it made the rear of the truck grip better in the corners.
twisted is offline
Old 06-04-2012 | 11:44 AM
  #24539
Resqnu
Less chassis roll , more stable in sweeper turn ....
Old 06-04-2012 | 11:48 AM
  #24540
Resqnu's Avatar
Resqnu
Thanks guys. Y'all keeping this mod? If so I will order parts today.
Resqnu is offline
