Tekno RC EB48 Thread >
Like Tree2Likes
Old 05-23-2012 | 09:28 AM
  #541
BashemSmashem's Avatar
Not sure what you mean by endbell ?
If you dont have the Electri Clutch adapter you will need it and springs to run the Tekno clutch bell .
http://www.teknorc.com/shop/tekno-rc...atent-pending/
BashemSmashem is offline
Old 05-23-2012 | 11:25 AM
  #542
Getting this http://www.teknorc.com/shop/tekno-rc...apter-springs/ Do I also need to buy these if I use the clutch kit? http://www.teknorc.com/shop/tekno-rc...18t-wbearings/
tdt1805 is offline
Old 05-23-2012 | 11:50 AM
  #543
teknorc's Avatar
Originally Posted by tdt1805
Yes, you need a clutch bell as well. You will want to gear the same as if it was direct drive.
teknorc is offline
Old 05-23-2012 | 12:04 PM
  #544
Thank you I sent you a pm with a question to.
tdt1805 is offline
Old 05-23-2012 | 01:36 PM
  #545
Cain's Avatar
what do you feel are minimum requirements for the specs on the mechanical brake servo like torque and speed.
Cain is offline
Old 05-23-2012 | 05:43 PM
  #546
teknorc's Avatar
.15 or faster, 150oz or more. You can do it with less, but this is a good place to start.
teknorc is offline
Old 05-23-2012 | 06:25 PM
  #547
hairymuffin's Avatar
Tekno, are you guys coming to grassroots at the proline track this saturday?
hairymuffin is offline
Old 05-23-2012 | 08:14 PM
  #548
teknorc's Avatar
I don't think we're going to make it to that one. We'll be at JBRL Nitro Rnd #3 and the SDRC Shootout race the following weekend though. The new car will be competing at both events if you want to stop by and check it out. Thanks.
teknorc is offline
Old 05-24-2012 | 12:24 AM
  #549
Just pre-ordered mine on the Tekno site, really looking forward to it as it will be my first buggy. Thinking a MMP and a Tekin 1900kv with a Elektri-​Clutch System. What size of pinion should I be looking at? This will be running in the Middle east with nice cool winters but very hot summers.
howse is offline
Old 05-24-2012 | 01:43 AM
  #550
spunkysandoval's Avatar
Originally Posted by HUGHES
We also just got 3rd place at the JBRL nitro series round 2, at Revelation raceway. The track was really rough for the mains, but the EB48 handled the track with ease & I was able to hold on to 3rd behind Drake & Hartson for a podium finish.
Nice work man! Really impressive drivers on that podium All of them
spunkysandoval is offline
Old 05-24-2012 | 02:12 AM
  #551
Do you have any recommendation of gears for the EB48 with a rx8/t8 1900kv combo? (European track style, fast and not many bump, 4s lipo)
I'm thinking of a 19 pinion
liva is offline
Old 05-24-2012 | 06:45 AM
  #552
Cain's Avatar
based on this info:
Diffs are 10/40 (4:1). The spur is 44t.
And using this calculator here:
http://scriptasylum.com/rc_speed/top_speed.html
If you already have a 1/8 electric you should be able to put in your current vehicle info, figure out the current estimated top speed, and then find what you need.
Me personally the tracks out here like speeds all the way up to 40mph+ .
I am thinking (assuming I go with a clutch bell setup) a Tekin 2050 motor (which on the calculator rates at 2120Kv) would give me what I need and still use clutch bells that are easy to find like from Tekno (they go up to 18T), or, my long shanks.
Now, probably doesn't matter though if you are going to use regular mod1 pinions.
Cain is offline
Old 05-24-2012 | 04:06 PM
  #553
Davidka's Avatar
When I ran nitro, I'd use ~100oz and as fast as possible. I think you can get away with even less torque with an E-buggy because there is no fuel/oil to foul the brakes.
Davidka is offline
Old 05-24-2012 | 04:49 PM
  #554
Cain's Avatar
thanks for the info. Right now, trying to decide which servo to keep here and if I want to try the mechanical brake thing again. I usually don't use brakes much, if at all.
Speaking of which, are we correct in assuming the new buggy will include all the hardware needed to run mechanical brakes?
Cain is offline
Old 05-24-2012 | 05:32 PM
  #555
Originally Posted by justpoet
I also plan on using an RX8/T8 1900 combo in this, likely with a 5000mah 4s pack, unless Tekno suggests otherwise. It should prove to be way more than enough power and allow it to run long periods and stay cool (I like to go practice for basically a day of non-stop running), even in the heat of sunny outdoor summer racing.
Blair's setup, as has already been mentioned, is a 1/10 ShortCourse Castle setup.
I'd like to know what was in the buggy that just won though, for comparison sake.
Anyone think a 1700 tekin t8 would be to much for this buggy? As I've already got that motor for another project?
muzzytt is offline
