SC10 4x4 Thread
I read further back that someone made a jig using 1.5mm washers so they had a guide of how much to cut off. If anyone else is thinking of doing this mod, I'd highly recommend that. I think that will help to keep your cut off straight. If it's not straight, you're going to have wobble like I have.
Mrplease & drol.
The clips in the shock bag are the travel limiters. You need 3 to 4 of those under the black rubber bumpers that are on the base of the shock shaft to limit up travel.
Without the limiting clips your suspension is allowed to travel too far causing the a arm and the cvd to make contact with the outdrive. That pushes the outdrive upwards and cones the shim under the sun gear loosening the gear mesh and then you get clicking or stripping of the diff gears.
A rear rebuild with a new set of gears is probably in order at this point, maybe while your in there a new diff case as well.
New shims under the sun gear (2 big gears in the diff).
Push the suspension ALL the way up, not just push the truck down to the table... all the way up. See the a arm and cvd getting into the outdrive?
This needs to become it's own thread so it's easier to find, many people have this same problem.
Mrplease & drol.
Mrplease & drol.
In any case, I will put at least 4mm of limiters on, maybe more (I currently have the boots on). I am not too excited about having to rebuild the diff because of this, but I can see from this thread that others have suffered far more to get us to the current point with this truck.
As far as this needing its own thread, I think what this needs is a product recall. If, out of the box, the uptravel causes problems in the tranny case, AE should notify its customers and provide a fix. R/C is one of the few consumer products where product flaws are accepted, even viewed as a challenge to be overcome by the community. In any case, thanks to the more experienced community for working these things out.
Part number or specs? Are these shims, or just washers?
I have been running the .3 wide Ofna for 2 race days without issue, but they're O.D. is smaller than that of the originals.
Is there a consolidated post of the "Must do" mods such as the up travel mod, and sun gear shimming? It's difficult to get through all the posts and extract the good info.
I'm new to the SC10 4x4 platform, and already this thread has been a great source of info.
Greg
Greg
Uptravel is the only "must do." Do it from the start, and the shimming is a huge deal. I've got a little wobble in my outdirves, but it has been running fine. The shims are still flat, and it's probably just the diff housing at this point. One day I'll get around to replacing it, but for now it runs good.
On pg 1345 of this thread, there's a link to a post on Ultimate RC where the mods are summarized.
Mrplease & drol.
I too am getting a clicking from the rear end on hard left hand turns with brakes. I rebuilt my front diff yesterday and the shims appears fine as well as the diff housing. I think I will tackle the rear end next and go ahead and replace those shims and inspect the diff housing.
I went to a race Saturday in Henry County GA. I got my butt kicked but had a blast doing it! My truck was very slow compared to the others and being new I found that I was running in an "Open" class. Since, I have upped my pinion to a 14 and moved my timing up to level 3. I did not know about that adjustment the day of the race or I would have upped it a bit and checked temp. With 0 timing on a 14 tooth pinion I was running about 120* on motor and 110-115* on ESC after a race so I have room to move. I am going to try and get to the track this week and do some testing.
Thanks for all you guys help in this thread and as fq06 has done for us new guys, please remember that when you talk about mods and changes, all of the terminology is rather technical if you are new like me.
i'm not really getting what your saying... your talking about the little white pieces need to go under the little black rubber washer at the bottom of the shocks correct? also you say i need new shims under the sun gear?@?@|!? what size are the shims? where do they go again? and where do i get them? is there a picture tutorial on this anywhere?
Stock shim is 5x10x.2.
Below are .3 thickness and tighten up the gear mesh.
http://www.trick-parts.com/product_p/tps5103.htm
You need new shims, stock or even better .3 thickness.
You probably need a new gear set for the rear diff as well.
There are instructions on diff assembly in the manual.
The new gears are usually needed once the diff starts clicking, thats gears stripping... but still, the .3 thick shims are best so get the along with
rebuild kit and you are golden.http://www.trick-parts.com/product_p/tps5103.htm
You need limiters boots or no boots, they just need to change that part of the instruction manual and point out that you need to limit regardless.
Stock shims are ok, .3 is better IMO, but most diffs need to be fine tuned anyway.
I loosened up the diff in my mugen mbx-5, so evey kit is different.
Someone with experience will probably know to double-check these things, but in any case, if there is a known problem, associated should at least have something about it on their website, and at best, provide replacement parts for people affected despite following carefully the published build instructions. Note that a FT driver including limiters in his setup is not sufficient notification, as it does not explain the possible problem with not using them.
Disclaimer: That's how I see these types of things, anyway. I certainly do not necessarily expect people to agree.
just got off the phone with associated and he explained the issue to me very detailed and now i understand. he said he'd be sending me the shims for the sun gear. he knew what the problem was instantly so i guess this is an issue with the truck. but he said this was a for sure fix...
5Likes
