RC10B4.1 FT/WC
Old 05-14-2012 | 09:47 PM
  #14791
B00t13g's Avatar
I'm running red rears with orange fronts. White kyosho springs front gold rear with 400cst all around.
B00t13g is offline
Old 05-14-2012 | 09:56 PM
  #14792
pink_sleeve's Avatar
Originally Posted by mhall
Has anyone had problems with their differential thrust bolt breaking? I have now broken two in the last week and I can not figure out why. Please help!! Thanks! Oh, I am running a 17.5t Tekin motor with a Tekin RS ESC. Gearing is 72t spur gear with a 31t pinion.
Over the past indoor season i managed to break 7 of them clean off but i was running a 7.5 on a high traction type track where we run slicks. Once i backed my slipper off some the problem seemed to go away
pink_sleeve is offline
Old 05-14-2012 | 10:03 PM
  #14793
D-Rek07's Avatar
Would the regular clay compound tires work on a blue groove clay track that isn't watered?
D-Rek07 is offline
Old 05-14-2012 | 10:11 PM
  #14794
Wild Cherry's Avatar
Hey Wild Cherry!
The funny thing is I had a certain owner of a certain track rebuild the diff for me. He wasn't there at the end of the week last week so I couldn't pick his brain and I didn't get in today. So, tomorrow I will see if he can fix it and answer my questions. See what happens when a guy tries to be a nice guy and fix a car for a person.
That Edit diff screw would be awesome but it says it's not available yet.
yeah no that owner guy ?
not know to be Trcr's diff expert , that's me .... (Jk)
Every one has me build theirs , I show um how and they never come back for help again ...
Lets hope its a Easy fix like a miss placed thrust ball ....
Wild Cherry is offline
Old 05-14-2012 | 11:00 PM
  #14795
easy e's Avatar
I had a trust assembly weld itself in the outdrive. Had to replace it all
easy e is offline
Old 05-15-2012 | 03:35 AM
  #14796
idrummerboy13's Avatar
Originally Posted by jdeadman
For me the perfect tire is the one that I can push hard but still be a little loose.
Loose is fast if you can correct fast enough.
in 1/10th buggy i don;t like too much traction in the rear. |Just enough to be able to steer with the throttle if I need to but using your finger be able to accellerate out of the corner with little of the front wheels on the ground
I agree. I like my rear bite as predictable as possible with the best balance between traction and corner speed. I never like to much steering that just gets u in trouble. I always run a tight diff also. I tried loosening it but it never worked the same. A tight diff works better for me.
idrummerboy13 is offline
Old 05-15-2012 | 05:43 AM
  #14797
Default Braking issue
Brand new RC10B4.1 Brushless RTR. First day ran just fine. 2nd time use, the brakes are locking up in neutral position. I set ESC to factory defaults, still no change. It is as if the brakes are on the whole time because of the sound and the minute i let off the throttle they lock up. Has anyone ran into this problem before? I am very new to RC cars so any suggestions or information would be greatly appreciated.
RC_Newb_1 is offline
Old 05-15-2012 | 07:21 AM
  #14798
That's funny Wild Cherry!! I will tell him I picked the wrong guy and see what he says.
mhall is offline
Old 05-15-2012 | 07:32 AM
  #14799
EvanAZ's Avatar
2 left
http://www.rctech.net/forum/r-c-item...nd-raiser.html
EvanAZ is offline
Old 05-15-2012 | 07:34 AM
  #14800
DanielC.'s Avatar
Been a few pages without any users' rides. Here's mine:
DanielC. is offline
Old 05-15-2012 | 07:47 AM
  #14801
What brand?
Krio is offline
Old 05-15-2012 | 08:39 AM
  #14802
Chad Smith's Avatar
[QUOTE=supafastsupra2;10735561]Been a few pages without any users' rides. Here's mine:
Nice pics!
Chad Smith is offline
Old 05-15-2012 | 08:42 AM
  #14803
Chad Smith's Avatar
What wing does everyone run? I noticed with the stock wing when the shocks are compressed the wheels hit the wing. Some wings have clearance for the wheels but wanted to know what was the most popular one.
Old 05-15-2012 | 08:45 AM
  #14804
brent701's Avatar
I use the B44.1 wing
brent701 is offline
Old 05-15-2012 | 09:06 AM
  #14805
DanielC.'s Avatar
JC Hi-Clearance
DanielC. is offline
