RC10B4.1 FT/WC
Old 07-06-2012 | 02:23 AM
  #16291
Lonestar's Avatar
Originally Posted by lagcisco
I bought this kit in about 2003 i'd say, gotta say, it holds up well!
The car had been collecting dust for many years, never even tracked it, until today.
Got some new tires on it and new lipo/brushless setup, refilled the shocks, re-lubed the diff and off she went, really impressed me. Now I'm excited about using the B4 Team Kit over my 22.
The car turns better, and I think even jumps better than my 22. I will need to put stock motors on both (only the 22 had a mod) and try them again, side by side.
Thinking of some mods.. already have modern lipo/brushless and the right tires. What is worth upgrading that really makes a difference? It's the original RC10B4 Team Kit.
Nada - it's still a very competitive car, I would change the shock o-rings though. The shock caps with bleeder screws are a very practical $5 hop-up, for the rest, run it as is and you'll be on pace with everything else if you have the right fingers... The only significant differences between a b4.1 worlds and the b4 really are the longer chassis... the rest is grossly the same
Paul
Lonestar is offline
Old 07-06-2012 | 02:32 AM
  #16292
From: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Awesome!
I'll spend more money on practice fees, tires and batteries.
lagcisco is offline
Old 07-06-2012 | 02:43 AM
  #16293
racene1's Avatar
Originally Posted by Jmuck69
SC=lame
2WD buggy= awesome!
racene1 is offline
Old 07-06-2012 | 06:32 AM
  #16294
Wildcat1971's Avatar
I also am using my b4 from 2003 ish. I did need to upgrade my rear shock tower. They increased the cutout for the battery strap. Some of my lipos fit with the old tower but not all. If you buy a pack and it does not seem to fit well, get the tower, plus the newer rear tower has a new inside hole and they removed the old outside hole,
Wildcat1971 is offline
Old 07-06-2012 | 06:34 AM
  #16295
Also, if you have a lot of losi 22 wheels, you can convert the b4 to hex. you will need the avid hexes and the sc10rs front hubs and a different front axle. If you really need me to I can goto amain hobbies and look up the part numbers for you :-) I have not had my caffeine yet and I am a bit on the lazy side.
Old 07-06-2012 | 07:16 AM
  #16296
Parts please
dougwalter911 is offline
Old 07-06-2012 | 08:17 AM
  #16297
t0p_sh0tta's Avatar
FYI, AE makes a plastic hex conversion, that's only $5. I run then when I want to run the hex leftovers from my 22.
t0p_sh0tta is offline
Old 07-06-2012 | 08:49 AM
  #16298
Originally Posted by dougwalter911
Parts please
this this and this
vw addict is offline
Old 07-06-2012 | 09:07 AM
  #16299
If you want a clamping hex this
http://avidrc.com/product/5/accesori...ccesories.html
Old 07-06-2012 | 09:08 AM
  #16300
how well do the plastic ones work? I was worried that they might pull off and get stuck in the losi/avil wheels
Old 07-06-2012 | 09:14 AM
  #16301
brent701's Avatar
They do
I drilled a small hole in mine for my SC10 and put a small set screw in them. works just like a alum. clamping one but cheaper lol
brent701 is offline
Old 07-06-2012 | 09:20 AM
  #16302
Originally Posted by brent701
They do
cool, I have not put mine on yet, trying to use up my stock rims atm. I plan to switch to hex, so much easier for tire swapping. The RS hubs can move forward or back and I believe the angle of the ball stud is different. How does this affect the b4's handling? And +1 to the hole and set screw.
Old 07-06-2012 | 09:22 AM
  #16303
Also, my b4 is a bit older than most. I honestly cant remember what caster hubs I was running 5 years ago. I know most people have switch to 30deg. And i "think" mine are 30, but unsure. Plus they are the old 2 hole style not the 3 hole. Is there any way to tell if mine are 20,25 or 30 deg caster? I really need to get a paint marker and mark this stuff.
Old 07-06-2012 | 10:16 AM
  #16304
3srcracing's Avatar
Originally Posted by Snafujg
So I just picked up a 4.1 World's roller and I'm looking for some ESC suggestions. I'll be running a Revtech 10.5 turn sensored motor. From reading thru the thread, it seems the newer MMP's with the attached fans don't fit too good without mod's being done. And I'm not really in a position to spend RS Pro type money. So I'm looking for some other suggestions on ESC's that I might be able to get in the $100 - 150 range. If I have to go to a RS Pro or a Venom to run the Revtech, I will. Just don't want to shell it out if I don't have to.
Thanks guys.
You could get the Novak Edge 2..
3srcracing is offline
Old 07-06-2012 | 10:24 AM
  #16305
sigh, I highly doubt you will find a better esc for under $200 than the Brushless Hobbies 120 amp esc. I have yet to meet a person that didnt like the smoothness, power and price of the esc. It is only $67 and definitely worth a try.
