LRP IX8
Old 05-15-2012 | 12:59 AM
  #136
dtr's Avatar
dtr
Originally Posted by DaveG28
Oh ok...that's pretty warm!! Have you had any thermal shutdowns?
No, it seems I have luckily just avoided it. Good luck having yours repaired!
dtr is offline
Old 05-17-2012 | 08:10 AM
  #137
DaveG28's Avatar
Ok, have a couple options to try thanks to kind people...but need to work out gearing:
The TP 1900 would have been ideal at a 13/14 pinion. Unfortunately I don't know the max rpm of hardly any 8th motors to know how to gear other vehicles!
I am going to be trying:
LRP 2200kv motor
Tekin 1900KV motor
I need to work out approx gearing to use on both, anyone know what difference the kv makes to the gearing/or experience of different makes?
I was thinking of starting on 13 on the tekin, and 12 on the LRP?
DaveG28 is offline
Old 05-18-2012 | 01:55 PM
  #138
DaveG28's Avatar
Have any of you guys updated to v1.6? It all works fine?
Thanks,
Dave
DaveG28 is offline
Old 05-25-2012 | 01:51 PM
  #139
David Home's Avatar
LRP 2200kv motor
Tekin 1900KV motor
I will be running my rc8.2e with the ix8 and lrp 2200, the spur on the car is 46t, i will be running a 16t pinion. This coupled with 2x 6000mah lipo's.
David Home is offline
Old 05-25-2012 | 01:53 PM
  #140
David Home's Avatar
Thanks,
Dave
I'm picking up the new V2 lrp usb bridge tomorrow when I'm at the track, so I will be updating the firmware when i get back home. I will report back on here if there is any issues.
Old 05-26-2012 | 04:42 PM
  #141
David Home's Avatar
Thumbs up
Updated the ix8 today to 1.6 firmware and all works fine.
Old 05-30-2012 | 07:49 PM
  #142
What changes are you seeing with the 1.6 firmware? Advantages/disadvantages
Brandon Powell is offline
Old 06-03-2012 | 04:40 PM
  #143
Would like to use in a 2s lipo. Was the problem fixed?
jmoneym is offline
Old 06-04-2012 | 09:01 PM
  #144
anyone know if the ix8 is good on 2s now after the USB update?
thanks, D
derbrylac is offline
Old 06-06-2012 | 04:42 PM
  #145
David Home's Avatar
I updated the firmware before I had even ran the car so I can't compare the new firware to what it was like with the old one, but, I did run the car in 2s after I had updated it, as I was still waiting on my new cells arriving and I only had the one pack. The car ran perfectly well, as I said, I don't know of the issues the old firmware had but it runs good now. Ran it yesterday with 4s and all I can say is WOW, so smooth and the brakes are unreal. This is my first LRP esc and I'm glad I chose it. Top notch stuff.
Old 06-17-2012 | 09:06 AM
  #146
2 different ix8's and 2 different issues. Had enough with this junk. First esc was cutting out horrible. Sent it back and they sent me a new esc and ran it yesterday and heated up beyond belief and thurmalled and motor also got real hot. So changed and lowered the settings as low as I could and in about 2 minutes it shut down... Just glad people I raced with tekins so I could race after traveling over 3 hours. Just hoping it didn't ruin my motor.....
smitty2802 is offline
Old 07-06-2012 | 12:56 PM
  #147
I bought one of these recently and finally have enough time on it to have an opinion.
Overall I like the ix8. For anyone on the fence I would feel comfortable recommending it so long as the unit they bought has the newest software already on it. Its very smooth and even though it doesnt have a ton of programming options it has what I would consider most important/useful and is pretty easy once you go through it once or twice. I like that it uses modular wiring so its easy to remove from the car.
I originally planned to run this on 2s in my scte but it had some issues with cogging and brown outs which I suspect were fixed in the latest software update. I chose to instead run this is my 1/8 scale buggy because I didnt want to buy yet another option piece just for functionality that it should have had in the first place.
I have also noticed that my temps are slightly higher than they were with my rx8 in the same car with the same setup. I figure thats because I was running the current limiter at 90%. I dont really notice a difference in performance, just temps.
Hack-N-Slash is offline
Old 07-06-2012 | 05:45 PM
  #148
jhautz's Avatar
Yea. I see temps 10-15 degrees hotter on my ix8 than I saw with my rx8. Never a problem though. I actually think its because the ix8 runs using the sensors only. The Rx8 is actually a little more efficient using the dual drive where is switches to a more efficient sensorless drive mode after the motor starts turning.
The thing I like about the ix8 is that its 6 months old and still running. This about the time my rx8's would die. So if this ix8 keeps running then im happy as a clam.
jhautz is offline
Old 07-14-2012 | 06:47 PM
  #149
Any update on the new firmware on 2s??
Sylvain is offline
Old 07-15-2012 | 09:02 PM
  #150
dfsc10's Avatar
thinking about purchasing the ix8. I had a rx8. just a couple questions... are they reliable? are they setup to run right out of the box with no programing?
dfsc10 is offline
