Like Tree5Likes
SC10 4x4 Thread
Old 05-10-2012 | 07:58 AM
  #22981
Cain's Avatar
The Ae VTS slipper performance is the best , better keep it handy as you may need it again ...
And that is in comparison to what exactly?
Originally Posted by SCTDan
So you had the opportunity to try the the v2 diff?
+1
Come on WC, unlike some others here I think you are better than that. Just because AE makes it doesn't make it the end all be all or else there wouldn't have been a need for the VTS slipper in the first place.
Cain is offline
Old 05-10-2012 | 08:14 AM
  #22982
MantisWorx's Avatar
+1
BOOOOOOM GOES THE DYNAMITE
MantisWorx is offline
Old 05-10-2012 | 08:56 AM
  #22983
Cameron Kellogg's Avatar
Originally Posted by CoyoteSlash
I will switch between the VTS and the v2 Center diff.
Reason being: I am about ready to throw the whole diff in the garbage after installing 5 of those pins.
This has nothing to do with the quality of the product and only with my annoyance of tiny parts that won't install quickly.
v2 Center diff tech tip:
Some small screw drivers have a magnet on the end (normally cheep give a way ones with company logo's on them). Stand up the pin on the end of the magnet and slide it into the hole first. Slide the magnet off the pin sideways so not to pull the pin back out. Do the pin first and then the ball. When taking the diff apart a bigger magnet can be your friend sucking up all the pins and balls before sliding the gear off.
Lay a towel accross you lap then sand the truck on it's side with the diff up for easy install. If you drop something the towel will keep it from disapearing on the floor.
Cameron Kellogg is offline
Old 05-10-2012 | 08:58 AM
  #22984
Wild Cherry's Avatar
Cain , tell me why you think the others are better ?
I will always recommend to everyone what the Team drivers themselves are using ....
This is why recommend the VTS ...
Ae is always making improvements to their products , the VTS did not just help the 4x4 Sc performance ...
VTS is also designed for the 2w ST ,SC & 2w mod buggys ...
I recommend for everyone to try on those rides as well .....
Cus Trcr's faster Ae drivers have just started using for them selves....
Wild Cherry is offline
Old 05-10-2012 | 09:16 AM
  #22985
Cain's Avatar
Cherry, you didn't just recommend it, you said it was the best.
So I am asking you why it is. And why I ask you this is because of the fact that I think you do have valuable input. Your last advice on the setup of the vehicle you sent me via email was quite helpful by the way.
If you are saying its the best because the team uses it, etc. It needs to be tempered with the fact that the team drivers apparently are not allowed to use any other products other than AE's, even if the product is actually better than what AE has produced at the time. (ex- prior to the VTS Slipper, MTK clutch basket)
Using that logic, its like me saying I am the "best" because I whip up on the kids with Tyco cars who are not allowed to use anything else with my SC104x4.
And if there is an advantage on some conditions to using the VTS slipper, I want to know as I can easily pick it up and keep it in the box for those if it is. Or, if as you say WC, its the best, the V2 Diff would then get regulated to the pit box for conditions where that excels.
The "best" choice will be the one mounted on the vehicle most of the time then.
And just to clarify, my experiences first hand have been with the MTK clutch basket and driven a few vehicles equipped only with the stock pad setup prior to the VTS setup. Based on that, the MTK basket was far superior to the stock pads. But I am assuming everyone else already knows that LOL.
Hope to get some experience with the V2 Diff soon here.
Cain is offline
Old 05-10-2012 | 09:25 AM
  #22986
Cain , only recommending what the Team driver's do as they have the most experience ...
You can try your best to say the team driver don't or can't use , this is simply not true ..
Anyone can see all kinds of custom stuff like Avid , MIP , Lunsford ect being used by the Ae team racers .
  #22987
n8b
Scott and Fred came up with a brilliant idea. Many thanks to the boys up in Michigan. The basket wasn't "needed" until AE produced one. Now it's great... Once AE makes a center diff will it then be ok for you to use WC?
n8b is offline
Old 05-10-2012 | 09:28 AM
  #22988
If I saw the team using n8b ?
Be the first to recommend to you as I don't try to give you guys advise based on less then the best most experience drivers Ae has ...
Old 05-10-2012 | 09:34 AM
  #22989
n8b
We appreciate your opinions WC, don't be afraid to try new things though. Everyone on this thread was talking about how good the basket was way before AE released their basket. But there was a few people who said it was not needed, and now it's the best upgrade that can be done.
If you tried the center diff I think you would like it.
Nathan
n8b is offline
Old 05-10-2012 | 09:36 AM
  #22990
Cain's Avatar
You can try your best to say the team driver don't or can't use , simply not true ..
Funny, I know a team driver for AE and he advised me he wouldn't be allowed to use an aftermarket part on his vehicle when I specifically asked him about it. So maybe it is part dependent, etc. But it does happen.
I was hoping to get more insight into what you were seeing or hearing from other drivers you associate with that made you feel that the VTS was the "best" as you said versus the other options out there like garodiscs, V2 Center Diff, etc.
For those who have actually used the V2 Center diff and a clutch basket setup (AE, MTK, etc), what conditions did you find the clutch basket was the best choice to go with over the V2 Center diff?
I am wanting to see if its worth keeping it in the pit box, or, maybe just the garodiscs, etc. to be ready for any conditions.
Cain is offline
Old 05-10-2012 | 09:38 AM
  #22991
Cain's Avatar
I appreciate that as I believe others do too. But, keep in mind that even the best minds don't get it right all the time. Just look at how the SC104x4 when it first came out was received and what all changed on it to get it to the point it is now.
Nathan
+1 on appreciating your opinions and I would like to hear yours on actually trying the basket vs diff.
Heck, maybe Marcus could send you one to try out on a loaner basis or we could chip in to get you to try it
Cain is offline
Old 05-10-2012 | 09:54 AM
  #22992
JayL's Avatar
some of the team guys were running the MTK basket clone before the AE one came out....
What we need is for Marcus to get one of the Ryan's on his team
JayL is offline
Old 05-10-2012 | 09:57 AM
  #22993
n8b
Talking
+1 on appreciating your opinions and I would like to hear yours on actually trying the basket.
I ran with the mtk basket on dirt and carpet and would say a basket is great on carpet. I tried the v1 diff on carpet and would say I lost a ton of punch.
I currently have the v2 center diff in, but don't have much time with it yet. I can say that just running out in the drive I have way more control than with the v2 diff over the VTS slipper. This weekend I should get some track time with both.
I've dropped a few dollars on rcshox products. Maybe I'll get some freebies soon.
n8b is offline
Old 05-10-2012 | 09:59 AM
  #22994
n8b
Either way, the mtk basket, VTS basket, V1 or v2 diff, or garodisks are way better than the stock slipper setup.
n8b is offline
Old 05-10-2012 | 10:03 AM
  #22995
Jay
Ryan's ?
NoT !
Kody is my favorite ...
Cain , I refuse to try to make Mantis or Mac 's products
seem less or diss ...
I only welcome them and their help they bring to all of us ...
