RC10T4.1 Thread.
Old 04-23-2012 | 07:17 PM
  #1201
B.A. Racer's Avatar
Originally Posted by gguertin145
I ordered a replacement chassis the other day and the one I got was made from the old plastic... Does anyone know of a retailer that carries the new plastic chassis or am I stuck ordering something on fleabay?
Why would you want the new plastic? The older plastic is much better with it being stiffer. If I were you I would run the older chassis
B.A. Racer is offline
Old 04-23-2012 | 07:20 PM
  #1202
Most of our tracks are low traction so I was looking for as much as possible... Thought that would help?
gguertin145 is offline
Old 04-23-2012 | 09:07 PM
  #1203
EvanAZ's Avatar
Default ***B4/T4 SC10 Screw kits*** Fund Raiser
I just posted this in the FS section. We are doing a fund raiser to help raise funds for our Cars -4- Kids RC Program.
Screw kits for the B4/T4/SC10.
http://www.rctech.net/forum/r-c-item...nd-raiser.html
Thanks,
Vince
EvanAZ is offline
Old 04-24-2012 | 04:28 AM
  #1204
B.A. Racer's Avatar
I your wanting more traction the new chassis would help.. I thought you were running on hard packed clay for some reason
Old 04-24-2012 | 05:55 AM
  #1205
You can get carbon parts for the truck :-)
rc10t3b4 is offline
Old 04-24-2012 | 06:04 AM
  #1206
ovalracer1m's Avatar
greg, what you need to do is go on ebay and find the people that are parting out new .1 kits. Only way to get then currently. I have bought 2 chassis this way. I pm'ed you the link to the auction on the nitro series forum.
ovalracer1m is offline
Old 04-24-2012 | 09:46 AM
  #1207
Thanks! See ya next weekend
Old 04-24-2012 | 03:57 PM
  #1208
LanceBuku's Avatar
Question,
What's the reason for gluing the servo saver and what part is actually glued?
LanceBuku is offline
Old 04-24-2012 | 07:06 PM
  #1209
I recently assembled a t4.1ft kit and the steering rack was binding up on the front brace above the bulk head. I bought a new servo saver assembly and it worked fine any ideas?
streeterbuilt81 is offline
Old 04-24-2012 | 07:11 PM
  #1210
nismomike's Avatar
You sure the ackermann was turned the right way?
nismomike is offline
Old 04-24-2012 | 07:13 PM
  #1211
bds81175's Avatar
Moderator
The two screws that hold the steering rack onto the upper plate can't be over tightened. I always tighten them until the rack won't flop back and forth on its own and then loosen it a touch. Is it possible you over tightened them?
bds81175 is offline
Old 04-24-2012 | 07:20 PM
  #1212
Yes the ackermann plate was installed correctly And I tighten the screws down the same way. I put it in my b4.1 and it does the same thing I Just don't know if it was a bad mold or if someone else has had this problem with the newer kits?
Old 04-24-2012 | 10:00 PM
  #1213
Odin544's Avatar
I had a similar issue when rebuilding my front end with new parts last week. Once I had all the screws holding the top plate down all tight the issue was gone. The top plate was a little tweaked out of the package but straightened out once screwed down to the chassis and no rubbing or binding in the steering.
Odin544 is offline
Old 04-24-2012 | 11:55 PM
  #1214
Does anybody here know if a complete t4 diff assembly will work in a t4.1 transmission? Thanks,
rifraf is offline
Old 04-25-2012 | 07:13 AM
  #1215
EvanAZ's Avatar
Thanks,
Vince
Still have a few left.
EvanAZ is offline
