Like Tree5Likes
SC10 4x4 Thread
Old 04-11-2012 | 09:14 PM
  #21256
sugs's Avatar
Originally Posted by Cameron Kellogg
I am very lucky to race for Murfdogg motor works. We have done a lot of testing and I like running his blue 5.5 motor with a 12.5 rotor. I do have a black 6.5 that i like too but i like the pop the 5.5 has. There is way more to a motor design than just putting a big rotor in it for SC. I have learned some about motors from Matt and he knows tons about brushless motors and especially his motors. I don't work on the motors I just runs what he sends me. My job is to race them he builds them. I will say that I have been out driven and out handled but never out motored.
Thanks Cameron, I'll check them out.
sugs is offline
Old 04-11-2012 | 09:19 PM
  #21257
Default help...clickin noise
greetings ppl...im sorry for this noob q..
im from malaysia..and the sc 10 is a new thing here we just picked up..
as for me..i just got a sc myself and so far ive ran about 30packs..untill recently...
i started hearing clickin noises from my sc...espeacially when i punch the throttle to the max...and its the worst when i accelerarte out of corners
ive tried everything...that i have read in ths forum..
locking down my clicker, gluin my clicker, checking and tighenin my belts,makin sure my spur and pinions are fine....the only thing i havnt check is my rear tranny..
its would be a hassale to tear this truck apart..so id like some advice...before i search deeper into the truck...
ive no clutch basket or pinned shaft...everything is stock...
thank you for the help...
xiswell is offline
Old 04-11-2012 | 09:35 PM
  #21258
fq06's Avatar
This should help
http://www.rcshortcourse.com/forum/t...eration-2.html
Make sure that the cvd and the a arm are not making contact with the rear outdrive.
fq06 is offline
Old 04-11-2012 | 09:54 PM
  #21259
Devigili22's Avatar
As said above. Also check your rear idler gear and the shims in the rear diff have been known to cause issues.
Devigili22 is offline
Old 04-11-2012 | 10:35 PM
  #21260
CentralCoaster's Avatar
Someone please design this so I can buy one:
Combination slipper AND clicker for front pulley. It will slip (adjustable) under braking, and lock up under power. (Or make use of a one way bearing instead of the clicker, same idea.)
The rear decoupled slipper design would stay as is (or upgrade pads/basket if needed for extra power). This retains the slip adjustability for forward drive.
The idea here is to have an adjustable clicker, instead of the on/off that it is now. Using the clicker makes it impossible to do heavy braking into sweepers (like the end of every straightaway of every indoor track i've been to). It also removes half of your ability to pitch the car down mid-jump.
With a slipper adjustment in there, you could now dial in some front brake. You could now balance how much turn-in you want with how much high speed braking stability you need.
The front slipper pads to be used should have a static coefficient of friction that is pretty close to the kinetic coefficient... so that braking slip is predictable.
Ok, now get to work, or else I'm buying a Losi and shitcanning this thing. I've checked all the stuff available, and none of it accomplishes this.
CentralCoaster is offline
Old 04-11-2012 | 10:46 PM
  #21261
Cameron Kellogg's Avatar
Your front slipper is already made.
The front pulley has a one way bearing in it and the slipper is used to control the front slip under braking. Not sure where he is with production with it though. It was supposed to be out a while back. Billy from fast laps does full size race trucks so he might just be busy with that now. Interesting idea.
Cameron Kellogg is offline
Old 04-12-2012 | 01:54 AM
  #21262
Sludge-T's Avatar
Hot Racing makes a one way front pulley bearing. I have it and it seems to work fine.
http://www.hot-racing.com/index.cgi?c=617
Sludge-T is offline
Old 04-12-2012 | 01:57 AM
  #21263
Originally Posted by jmc5313
I just finished my FT kit and (I'm a newb )...I assembled it with all of the included parts and fluids...so I have the 30k in the front differential....would that cause a$$ loose off throttle? ....I'm running on a dusty smooth mid grip track...I'm also running blue front sway bar and orange rear...just like the manual said....but I know it isn't the proper set up for my track.....please help....and if possible I'm a newb so if u cud dumb it down!!!!!! Thanks!
I used the 30k as well but not all of it, I added about a 1/4 5k to thin it up a bit.
I don't have the maths skills to work out what that has resulted in.
Lots of people seem to be running about 10k so I wanted to get nearer to that.
Beachbuggyphil is offline
Old 04-12-2012 | 08:29 AM
  #21264
Wild Cherry's Avatar
Default Missing
Where did the Coyote go ?
been a week or so ...
Wild Cherry is offline
Old 04-12-2012 | 08:30 AM
  #21265
Evil Genius jr.'s Avatar
9 days to be exact....
Evil Genius jr. is offline
Old 04-12-2012 | 08:41 AM
  #21266
Dano628's Avatar
It would be the equivalent of 23.75k close enough to say 24k .
Dano628 is offline
Old 04-12-2012 | 09:34 AM
  #21267
CraigMBA's Avatar
Welcome to the club! This is always an issue for this truck on tracks like this. I ran 10K, 20K, 30K, 60K and it didn't change the off power loose issue, but what I did change that worked was to recouple the slipper. I have an early truck and had to make parts, but you can just buy this inner slipper plate and bolt it on because you have an FT chassis.
http://teamassociated.com/parts/details/91188/
Be warned, the truck will not rotate as well in the center of the corner with this change. If this is a problem, you can try lighter than 30K front fluid (slightly more steering into the corner) and/or over-driving the front (more steering off the corner).
CraigMBA is offline
Old 04-12-2012 | 10:35 AM
  #21268
Mizchief's Avatar
Default Thicker front diff oil for more on power?
According to The Guide: http://jq-products.com/the-news/43-t.../160-the-guide
Thicker front diff oil is supposed to increase on-power steering when using a center diff. I thought that I was getting more on power when I went lower, but I think I may have misunderstood what I was seeing as "better cornering" in general and I as actually getting more turn in.
What do you guys think? seems like on-power was getting lost more to rear weight transfer to me.
Mizchief is offline
Old 04-12-2012 | 10:36 AM
  #21269
Cain's Avatar
based on what I experienced, I found improved steering offpower by dropping the diff oil weight from 20K to 7K. I believe actual on-power steering for me at least felt similar. But this was on a very tight track with 180s, carpet (50x50).
Cain is offline
Old 04-12-2012 | 10:44 AM
  #21270
Try 10k in ft & no over drive
dailed
more steering from thicker oil , all smoothed out by not using overdrive
use 7k in back with
Thicker in ft = more on-power steer , more pull on exit out of turn
