Serpent 811E Buggy Thread >
Like Tree5Likes
Old 03-25-2012 | 05:01 PM
  #1861
TheBackmarker's Avatar
Originally Posted by w_dupree
My buggy will be here tomorrow, can't wait. Tried searching but not really finding an answer, whats the final say on an aluminum servo horn?
The Dynamite Al servo arm is working fine for me. No problem at all. Same arm I've used for years on Associated and Mugen
TheBackmarker is offline
Old 03-25-2012 | 05:24 PM
  #1862
BigRon's Avatar
After stripping out the stock one (without a backup available) I threw on an aluminum answer horn. It's been fine ever since. The stock horn fits better though.
BigRon is offline
Old 03-25-2012 | 05:56 PM
  #1863
schmoey's Avatar
Default turning issue
its pushing on-power. i'm running 5-5-3 and have serpent 300wt shock oil in the front and rear. 2.5m front sway bar
schmoey is offline
Old 03-25-2012 | 06:22 PM
  #1864
tony montana's Avatar
My shocks are at 8 hole 1.3mm pistons, blue front spring 40wt oil. Rear 1.3mm 8 hole pistons, 32.5 oil and yellow springs. Opt 2 steering rack. If that doesnt work use 12 degree front hubs
tony montana is online now
Old 03-25-2012 | 06:57 PM
  #1865
Is it that the horn needs to be tall, sit off the servo more than others, Like the HPI Ve8 horns or do they need to be pretty flush?
w_dupree is offline
Old 03-25-2012 | 07:34 PM
  #1866
atl darrick's Avatar
Originally Posted by tony montana
Wow, I didnt think anything could outsteer this car. Is the car pushing or is the front end sliding?
Just raced my eco over the weekend and it outsteers the serpent. Surprisingly by a lot....and I still have another hole I can go in to get more
Gonna have to say I like my eco better. Its so stable and forgiving
atl darrick is offline
Old 03-25-2012 | 08:33 PM
  #1867
RCmayor's Avatar
Not really, there is just a real narrow pathway for it to move in. The servo arm could be a little shorter and work, but the stock one is max height.
If you use a plastic one, be sure to use a small steel washer bigger than the intention in the plastic. It helps to keep it secure by pressing on the outside of the servo arm.
RCmayor is offline
Old 03-25-2012 | 10:23 PM
  #1868
JPKinsella's Avatar
Default First day test
First day test with the serpent when good the car had lots of corner speed and was very predictable easy to drive hard.. Of course first pack out I did strip servo horn even with the super glue trick.. But I found a racer edge alum. servo horn that worked perfect. also had the motor move on a hard case hit. but thats it. Had a couple of local sponsered guys drive it the consence came back best 1/8th scale yet.. My buddy has the Mugen ECO it's very stable and easy to drive slow but is hard to push and drive fast and has no corner speed compared to the snake.. and as for the Losi 2.0 I just got rid of the snake is better everywhere......
JPKinsella is offline
Old 03-25-2012 | 10:52 PM
  #1869
mrnizzles's Avatar
Default problem with a defect
looks like I have a manufacturer defect on a small coupler that fits in one of the rear axles... its a small "bur" inside the small copper colored coupler that fits inside the round end of the drive bone.
the drive pin will not fit through it, it gets stuck on the bur a third way through.
#600197 - not sure the name, wish the manual called out the NAME of the part in addition to the number!!
Can't find any parts through Amain or AbsoluteHobbyz... looks like there arent ANY drive axle parts online, so I dont know where to get one of these or even a cvd rebuild kit or something... looking for nitro 811 parts too.
I will try filing it somehow maybe with a small drill bit, but really I just want a new part.. even with filing I dont think it will fit right.
I tried taking a pic, but its so damn small nothing came in focus.
** Ahh found this -
http://www.walterrchobby.com.au/inde...-insert-2.html
http://www.serpent.com/product/600197/description/
_
mrnizzles is offline
Old 03-25-2012 | 11:41 PM
  #1870
RCmayor's Avatar
File and hammer it in. lol small "burr" is nothing.
RCmayor is offline
Old 03-26-2012 | 12:02 AM
  #1871
JPKinsella's Avatar
Absolute hobbz.com has them instock also
Old 03-26-2012 | 05:10 AM
  #1872
rcjunky10's Avatar
Call the folks at Desoto Racing (305-677-3253) , Ricardo is the guy I've dealt with, and they will send you a new part.
** Ahh found this -
_
rcjunky10 is offline
Old 03-26-2012 | 07:04 AM
  #1873
This is what I use http://www.horizonhobby.com/webapp/w...pe=productgrid
Choose your color and spline(servo brand) and install with a button head screw through the ball supplied for the plastic arm with a 3mm flat nut on the back side threadlocked. It will work perfectly with ample clearance.
Old 03-26-2012 | 07:32 AM
  #1874
blade329's Avatar
That certainly wasn't my experience with it. I thought it was terrible on rough sections of an outdoor track. It was more stable than the RC8Be, but not even close to the stability of my Ve8. Still, overall though, I thought it was a good buggy.
blade329 is offline
Old 03-26-2012 | 08:57 AM
  #1875
** Ahh found this -
_
absolute has them http://www.absolutehobbyz.com/produc...oducts_id=2012
and a main has them http://www.amainhobbies.com/product_...t-Insert-Set-2
mdmaxx is offline
