Serpent 811E Buggy Thread
#1847
I got this charger, works great. Protek lipo's work great also.
#1848
http://www.amainhobbies.com/product_...S-10A-200W-x-2
#1851
You can always try it for yourself but I didn't even bother. Shoe Goo-ed it to the servo and no issues. And you can see if the transponder is getting power without having to take the tray out.
#1852
A better design will be when they lay the servo down, and build a shelf/protective cover for the esc on top. With these plastics, you would need ALLOT of heat to get them to start to melt.
#1853
Things are pretty tight in there. Everything is mounted as low as possible. Adding a shelf over the servo would raise one of the the heaviest components of the car.
For the transponder, I think it was originally planned for under the speedo, but even the manual shows it behind the servo. Mine stays under the speedo for now, but anything missed and it moves out.
I wonder if it is the close proximity of high powered electronics, or the aluminum plate that causes the issue.
#1854
ok guys, i just raced my 811e for the first time yesterday at the warehouse(indoor track in helena al). the car is setup to the stock specs. overall the car felt pretty good but there are 2 hair pin turns that i was having problems with. i couldn't the car to turn like i needed it too and was being out steered by most every one in those turns. any suggestions, thanks
#1855
#1859
5Likes
If it doesn't rain, tomorrow will be the maiden voyage.
