SC10 4x4 Thread
I think AE bet on the wrong horse for solving the slipper issue. (no offense MTK!)
The decoupled slipper biases torque (by slipping) to the wheels with the most weight transferred to them (wheelies on hard acceleration).
The Mantisworks V1 ball diff worked is to bias torque the opposite way by putting maximum torque to the axle with the least weight transferred to it (ballons the front tires under hard acceleration).
The pin modification (coupled slipper) splits torque evenly and does not bias.
The Mantisworks V2 ball diff allows the user to change the number of pins to control how much you bias it to the front, which puts it somewhere between the pin mod and the V1 ball diff under power.
Sort of. The problem isn't the drivetrain, it's how you are describing the weight transfer. All those things you mention would work and be correct right up to the point where you have enough weight transfer to lift a tire (or tires). Once you do that, there is no more weight to transfer.
5Likes
