Like Tree5Likes
SC10 4x4 Thread
Old 03-14-2012 | 08:13 AM
  #19186
oldandnew's Avatar
Thank you. I am not running saddle packs and I am not sure if I want to get any for just this one truck. But from what your saying I would benifit from the brace. Thank you.
oldandnew is offline
Old 03-14-2012 | 09:03 AM
  #19187
vito's Avatar
i see novak has a new esc and 550 motor out with x drive for the 4x4. in a few post back we found out the 550 fit with no mods . thanks.
vito is offline
Old 03-14-2012 | 09:22 AM
  #19188
Mizchief's Avatar
http://youtu.be/tFI5Sv9Y2c0
Mizchief is offline
Old 03-14-2012 | 09:25 AM
  #19189
rcmark17's Avatar
Originally Posted by AzFittin
RCMark ... page 921 post 13807 is the original. It has some good pics but if you want details on how to do it you will need to do some searching. I would include those pages as well but do not know them From what I remember a drill press (to keep things square) with a cut off wheel was recommended at some point. This, at least, should get you pointed in the right direction.
Hope that helps.
Jason
Thanks that did help. It explained all my questions.
rcmark17 is offline
Old 03-14-2012 | 09:26 AM
  #19190
Mizchief's Avatar
Remember too that Saddle packs are just stick packs cut in half long ways, nothing stopping you from using saddles inline the same way you would a stick pack.
Mizchief is offline
Old 03-14-2012 | 09:28 AM
  #19191
vito's Avatar
the set up i like has some bad post its ok as i cant soder and no lhs here i dont drive and to fine some help here where i live its a hobby dead land here. i see if my mom will take me to my sisters and shop at rpp hobby
vito is offline
  #19192
rcmark17's Avatar
Dont worry to much about the Novak esc and 550 motors. I have been using a 1st gen. GTB with a Tekin 7.5 550. The esc does not get warm and the motor runs cool.
rcmark17 is offline
Old 03-14-2012 | 09:31 AM
  #19193
vito's Avatar
iam getteing this one http://www.amainhobbies.com/product_...-Connector-45T as i dont sorder well shake to bad. thanks for all the help. vito
vito is offline
Old 03-14-2012 | 09:52 AM
  #19194
railer80's Avatar
Outdrives are my only problem right now, gonna try son rubber stops with the shafts for the arms. Love the rest of the truck.
railer80 is offline
Old 03-14-2012 | 10:07 AM
  #19195
vito's Avatar
vito is offline
Old 03-14-2012 | 10:30 AM
  #19196
JEFFs SC10's Avatar
Originally Posted by Eaglesrx
I've been trying to read through all of the page results for exotek chassis. But, there are quite a lot.
I'm trying to figure out for the factory team sc10 4x4 that comes with the chassis brace if I need the exotek chassis. It seems that you can either just have the exotek chassis or have the chassis brace and add weight as needed (i.e. essentially the factory team version).
However, would it be overkill to have the exotek chassis on the factory team version (essentially the exotek chassis and the chassis brace at the same time)? How many of you guys run both the exotek chassis and the chassis brace at the same time? How does it perform with both? Seems this way, you would eliminate the need for weights.
Thanks and sorry if this has already been discussed.
The exotech add weight centrally and down low, adding weight on the sides is not the same effect.
you don't need the brace with the chassis, trust me on this. (you ain't gonna bend that thick aluminum)
we run the exotech cause the truck needs more weight, especially if you run outdoor. If you run indoor the stock ft setup will probably work just fine.
JEFFs SC10 is offline
Old 03-14-2012 | 11:12 AM
  #19197
Excellent info. Sounds like the chassis brace and the exotek at the same time is really unnecessary. However, is it detrimental to make it too stiff with both on? Just wondering since the FT kit already comes with the chassis brace and I'd like the weight from the exotek. There was a previous post where he wanted both on to completely eliminate chassis flex as a variable when figuring out what aspect to tune.
So, maybe we should start a survey: how many of you guys have just the exotek, how many of you guys have just the chassis, and how many of you guys have both?
Thanks,
Eaglesrx is offline
Old 03-14-2012 | 11:53 AM
  #19198
One way to tell if you need both the aluminium chassis and the brace on at the same time is to stand on the brakes on a high traction track and see if the belt skips. Mine did on a carpet track but I got used to it. That was in stock form and not with an Exotek chassis or brace. I installed a locally made brace (I got a deal on used CF broken arrows) and the first thing to go was the skipping belt. If you put the chassis in and the belt doesn't skip, then you don't require the brace to take out the front/rear flex. Sometimes a bit of flex can be a good thing and sometimes it can lead to other issues. I found that on a carpet track, the brace made a significant enough change to use it but not bother getting the aluminium chassis. Take care.
Don
PS> The tension was correct on the belt without the brace in place. The tension remained exactly the same after the brace was installed but the skipping stopped.
Keyrigger is offline
Old 03-14-2012 | 11:58 AM
  #19199
oldandnew's Avatar
Are you saying that my stick packs would fit in the updated batt. brace? Or the other way around, if I did get saddle packs they would fit inside of anything that took stick packs? Don't know if I want to get the update kit if I am not going to use the batt. portion of it. Seems like it is half of the kit.
Thanks again for the help.
Old 03-14-2012 | 12:47 PM
  #19200
Don
Thanks for the info. When would a bit of flex be a good thing? decreasing your risk of breaking something? I can't imagine it helping to improve suspension. I would think making the care more stiff would make the care more responsive? I'm probably way off base.
Eaglesrx is offline
