Like Tree5Likes
SC10 4x4 Thread
Old 03-23-2012 | 09:39 PM
  #19846
CoyoteSlash's Avatar
Ran at PRCR Wed and Thurs
Ran at homebase Meldrum Park Today, Friday.
I'm really happy with the Center mounted battery. The thing won't roll over anymore 'at all'. Let another fellow drive it who had a stock truck, and even though he was 'very' fast which impressed me alot, (he was a great driver) He really liked how my truck drove.
Got in 4 packs a day at PRCR with great results. I also found out if there is "enjoyable" music playing on the radio in the building, my lap times DRASTICALLY change by 2 seconds a lap.
At meldrum, running the same setup minus a tire swap, it runs fantastic. (Blown out large 1/10 track) The thing rips and I can't roll and I no matter what I do I can't get the back end to respond unintentionally.
- 100% Full FT (prior to new FT kit pieces)
- Pro 4 4000 (1 pack-12minutes= damn hot)
- MMP esc (hot'ish)
- RCSHOX Dualrate Pistons 22.5/25
- RCSHOX Center Diff V1 (v2 on it's way soon I hope)
- Center mounted Battery modification
- Stock Body: No cutouts
- Spektrum 6040 Servo
After my nightmare at the previous track layout, which I'm realizing was me needing to learn how to drive, and all the breaks in the steering issues... I'm finally back to enjoying the truck again. It sat in timeout for a while.
The FT upgrade kit is ordered and I'll be using that VTS slipper indoors if i'm not a fan of the V2 slipper. (driving style) but with how the original holds my truck on the track, I'm sure i'm going to be stoked. I think I need to go to 25/27.5 though. I truly am getting chassis slap on some silly stuff. (I taped the belly and repeated the same area over and over. It's just a fall that's kicking the weight off the backend causing some squirly)
All in all. w00t!
CoyoteSlash is offline
Old 03-23-2012 | 09:49 PM
  #19847
vito's Avatar
Only way for some to stop the 1st slipper plate to not slip was to tighten down the slipper all the way , if you adjusted the slipper properly the first plate could slip...
You can also use a thin tooth lock washer to help the first plate grip the top shaft , that helps ....
hows this mod work on a stock set up i dig to fine it?
vito is offline
Old 03-23-2012 | 09:55 PM
  #19848
CraigMBA's Avatar
Results from the Cactus Classic (qualifying just finished for the day)
Position Driver Name Car # Laps Race Time Fast Lap Behind Qualifier
1 Truhe, Mike 5 12 5:01.291 24.408 3
2 Phend, Dakotah 12 5:01.924 23.599 0.633 1
3 Frank Root 2 12 5:02.531 23.976 0.607 5
4 H�l, Hupo 6 12 5:04.231 24.242 1.700 7
5 Wernimont, Carso 12 5:11.879 24.731 7.648 6
6 Amezcua, Travis 12 5:18.156 24.365 6.277 9
7 Numedahl, Kody 9 4:59.819 24.331 8
8 Neumann, Joern 5 2:06.974 23.837 4
Note the difference between Phend's fast lap at 23.599 and Numedahl's fast lap at 24.331. Hartson's fast lap is a 24.539, Max Fluer's fast lap is a 24.997. They are currently 8,9,10.
Users can draw their own conclusions as to what that means, but IMO, being .7-1.4 seconds per lap off the pace is never a good thing.
CraigMBA is offline
Old 03-23-2012 | 10:01 PM
  #19849
old&slow's Avatar
more cheese ha ha
old&slow is offline
Old 03-23-2012 | 10:02 PM
  #19850
Cameron Kellogg's Avatar
Round 2 Lutz was the only truck to go 13 laps so move everyone down one.
This is what my rant was about yesterday. AE toped the boards in all other classes. AND its the same guys that always get the job done. Just saying.
Cameron Kellogg is offline
Old 03-23-2012 | 10:06 PM
  #19851
CraigMBA's Avatar
Earbuds, FTW.
CraigMBA is offline
Old 03-23-2012 | 10:13 PM
  #19852
CraigMBA's Avatar
Oh, I got that, but his fast lap was only a 23.9.
I concur.
Originally Posted by old&slow
more cheese ha ha
Or something. Seven tenths is an eternity. A second and a half?
CraigMBA is offline
Old 03-23-2012 | 10:41 PM
  #19853
ktm11rider's Avatar
Just about done building my Factory Team Truck. Where are you guys putting your RX8s with this setup? With the new FT saddle craddle the rx8 does not fit on either side.
ktm11rider is offline
Old 03-23-2012 | 10:51 PM
  #19854
Earbuds, FTW.
I'm putting music on my Zune as I type.
Edit: inb4 zune-harassment
Old 03-24-2012 | 12:00 AM
  #19855
Wild Cherry's Avatar
Kody da man !
,we were texting & rooting 4 um all night tonight ....
Wild Cherry is offline
Old 03-24-2012 | 12:27 AM
  #19856
CraigMBA's Avatar
I find tunes exceptionally useful when
  • The race announcer annoys me and I don't want to listen
  • Some puke is next to me on the drivers stand sees fit to bitch the whole race at racers, turn marshals, whatever
  • I find myself in a chatty mood
  • Stuck next to the generator because I got to the track late and got the primo pit spot
  • I need to chill for one reason or another
When I used to play poker tournaments, I always had them in, but just barely loud enough where I could hear them. If somebody who was totally obnoxious got sat next to me, I'd just crank it up where I couldn't hear them anymore. Didn't do much good if they smelled bad, but if the other opponent was attempting to put you on tilt so you could take advantage of you, it worked like a charm.
CraigMBA is offline
Old 03-24-2012 | 12:33 AM
  #19857
Old 03-24-2012 | 04:10 AM
  #19858
Interesting. Trying to figure out what happened. Either: 1. Phend/truhe r just better drivers than these guys. 2. numendahl/hatson/flurer got pushed out o the way by the heavy losis. Or 3. The ae is not as fast as the losi on the track??? I find #3 hard to believe. It's probably a combo of the first two reasons? I'm probably way off base here.
Eaglesrx is offline
Old 03-24-2012 | 05:53 AM
  #19859
Originally Posted by Farmer_John
You can solve the "popping" issue by going to separate balls, caphead screws and washers just large enough to "capture" the rod end. The issue would probably be finding the proper sized balls...Ask Coyote if he has any!
Thanks, Farmer_John! I'll look into this.
SBWheels2008 is offline
Old 03-24-2012 | 06:06 AM
  #19860
darryl80's Avatar
Cool
will the sc10 4x4 wheel hexes below fit on the sc10 2wd FT?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=270928919048
any help would be very helpful.
darryl80 is offline
