Like Tree5Likes
SC10 4x4 Thread
Old 03-22-2012 | 02:25 PM
  #19756
CoyoteSlash's Avatar
Yote you would know ...
Oh man... ya' got me now.
CoyoteSlash is offline
Old 03-22-2012 | 02:35 PM
  #19757
Wild Cherry's Avatar
How yeah like my homemade brace ?
Wild Cherry is offline
Old 03-22-2012 | 02:42 PM
  #19758
Cameron Kellogg's Avatar
geeezzz, at least sand off the Traxxas logo.
Cameron Kellogg is offline
  #19759
Whoooaaaa!!! That brace isnt factory team certified!!! Take it off immediatly
rickybobbyxxx is offline
  #19760
WC, are you running without your belt tunnel?
jnyrcr is offline
Old 03-22-2012 | 02:45 PM
  #19761
You seen it here first!
Old 03-22-2012 | 02:50 PM
  #19762
felt like
getting some serious double Traxxazz brace action going on.....
Old 03-22-2012 | 03:39 PM
  #19763
Farmer_John's Avatar
If you stroke it anymore, WC, you're going to make a mess... Seriously.
Don't blurt out things like that! You'll scare everyone!
Same can be said about you, jackhole. (I'm on prescription narcorics right now. You can only take 100% of what I type seriously...)
Farmer_John is offline
Old 03-22-2012 | 03:42 PM
  #19764
vito's Avatar
got to try it out some to day i had no brakes and it did not stop i like it a lot and the slipper is tight and still slipps some time to get some new parts
vito is offline
Old 03-22-2012 | 03:43 PM
  #19765
felt like
You got a part number on that red rod?
Old 03-22-2012 | 03:57 PM
  #19766
Brace
Traxxas # 5319x
Old 03-22-2012 | 03:59 PM
  #19767
vito's Avatar
as a basher i need the brace and new slipper set up right?
vito is offline
Old 03-22-2012 | 04:01 PM
  #19768
Default lost rear after spring change
Guys I put the white front springs on the rear to try and improve the jumping of the truck. I like the way it jumps now but I lost my rear traction. It now just wants to drift around the corners on throttle and just slides off throttle. What can I do to get the rear back under the truck. I am running the rtr with the center diff and stock diff oils. I don't have any shims under the ball studs and camber is -2 front and rear with 28mm ride height. Also using stock shock oil weights that came in the truck.
Jody
jodyfj40 is offline
Old 03-22-2012 | 04:20 PM
  #19769
JEFFs SC10's Avatar
lower your ride height in the rear
JEFFs SC10 is offline
Old 03-22-2012 | 04:26 PM
  #19770
ilanstylz's Avatar
Originally Posted by Robert421
What is the part number for the ball diff? Is there more than one supplier? I would like to get one for my SC10
Here is the link on rctech:
http://www.rctech.net/forum/electric...-services.html
There is only one supplier, which is Mantis, PM him and he can answer all your questions......
ilanstylz is offline
