Like Tree5Likes
SC10 4x4 Thread
Old 03-10-2012 | 09:21 PM
  #18976
CoyoteSlash's Avatar
Well I finished my chassis.
Other angles:
http://img833.imageshack.us/img833/3...0205811510.jpg
http://img687.imageshack.us/img687/8...0205855905.jpg
I take no credit whatsoever for this design.
I'm glad I did this. I was still very sour about buying saddles and this will be enough for me to keep serious but not spend any more money on packs I don't want.
CoyoteSlash is offline
Old 03-10-2012 | 11:23 PM
  #18977
Vegatron75's Avatar
Here's a video of a local race I was in. I'm the gold truck...
http://youtu.be/AnvKOGjpZ4A
Vegatron75 is offline
Old 03-11-2012 | 12:00 AM
  #18978
White fronts in the rear and the 2wd carbon rear hub pieces made for a level jumping, slightly drifty truck on high grip indoor clay (WCRC). Not "Ryan" fast, but very drivable. Woulda liked to get more time with it, but the ESC died just into the second pack...
maddysdaddy is offline
Old 03-11-2012 | 04:01 AM
  #18979
hotrod1933's Avatar
Default stripped spur
need help. Stripped two spur gears in two packs ?? Running hobbywing ten turn sct combo 2s indoor small 45ft x 25 indoor carpet track. only have 48 pitch was running 93/19 no problems then re geared to 93/16 and got about 3 packs stripped first gear. bought 87 locally (waiting 32pitch to come from amain) re geared to 87/17 close to old 93/19 and got about 5 mins and crunch spur gone. Did not get time to check temp but could touch motor for at least 15 secs before hurt so not super hot. Used to run rc and slots years ago so i know how mesh should be did not seem too loose had slight rock at tightest spot. Am i missing something. Are 32p gears better. How tight to run. Gearing tips pls. Not sure if stripping on power or brake seems to start on brake. Sorry for long post trying to all info.
hotrod1933 is offline
Old 03-11-2012 | 04:55 AM
  #18980
48p isn't really meant to handle high powered brushless systems in heavy trucks. The teeth are just too small. 32p has much bigger, thicker teeth.
Arakon is offline
Old 03-11-2012 | 06:42 AM
  #18981
I have been thinking about picking up the new FT SC10 4x4 when it comes out, anyone have any set up advice/sheets/must haves for a 1/8 loose dirt track ? I want to hand my SCTE off to the boy and try this truck next summer out doors.
Manatarms25 is offline
Old 03-11-2012 | 07:13 AM
  #18982
boborc's Avatar
I know this is a little off subject but does anyone know if Xtreme R/C Magazine is still in business??? I have been subscribing for years now,my subcription is good till june but I have not seen a magazine in Months. I have sent 3 emails in the last week with NO response.
boborc is offline
Old 03-11-2012 | 07:55 AM
  #18983
BlueGlowBoy's Avatar
http://www.rctech.net/forum/electric...-magazine.html
BlueGlowBoy is offline
Old 03-11-2012 | 08:47 AM
  #18984
SCTDan's Avatar
Other angles:
You might want to take the lead out of the side pockets and put some right in front of the battery on the centerline. Made a difference in the handling of mine when I went to the center mounted battery.
SCTDan is offline
Old 03-11-2012 | 10:14 AM
  #18985
JEFFs SC10's Avatar
did anyone else see that one of his battery posts lies directly underneath the belt cover? how you supposed to put the leads in there??
JEFFs SC10 is offline
Old 03-11-2012 | 10:22 AM
  #18986
SCTDan's Avatar
There is plenty of room under the belt tunnel. I have my negative wire soldered at 90deg to the top of the connector and it fits fine.
SCTDan is offline
Old 03-11-2012 | 10:28 AM
  #18987
pakk's Avatar
I hope that works. I really dislike saddle packs, but I do have a few good sets.
pakk is offline
Old 03-11-2012 | 10:40 AM
  #18988
I don't actually own the truck yet, placed my pre-order and anxiously awaiting its shipment. I don't currently run saddles but out of curiousity, what don't you like about them I've been considering going to them but would like to gets drivers opinions of them. Thanks, the help is really appreciated.
FTsc104x4 is offline
Old 03-11-2012 | 10:57 AM
  #18989
SCTDan's Avatar
If you are referring to the center stick mount it works very well. I've been running a similar setup since last fall it really improved the handling for me.
SCTDan is offline
Old 03-11-2012 | 11:19 AM
  #18990
MantisWorx's Avatar
Even better than that would be to order some .062" lead sheet from Mcmaster and lay it down directly under the battery!!
MantisWorx is offline
