Team Associated RC8.2e Thread >
Like Tree19Likes
Old 03-10-2012 | 01:59 PM
  #841
Originally Posted by heavyjeffd
Well, whatever works for you.
But I'll always take a battery that's half a pound lighter over one that isn't, especially when I don't need any more.
i experimented last year with different weight batteries, my car always handled better and more consistant with the heavier battery. power was also more consistant throughout the run
R.M.S is offline
Old 03-10-2012 | 02:03 PM
  #842
Originally Posted by bigBoyBigToy
It feels jus like the 10th that I also run unreal
Smoothness and braking and runs super cool I've ran tekin also in 1/8 and I'm in love with the Orion r8 and 1950 combo!! Just butter smooth...
Now the big test will be outdoors which starts in 2 weeks that will be the real test of its durability then is when I find out the whole package.. But the whole indoors season has been flawless... I did hav to replace the fan ,I just put a tekin fan on it..
Butter smooth
Cool, thanks for the input. You may have just cost me $350.00,
R.M.S is offline
Old 03-10-2012 | 03:24 PM
  #843
el Bourlando's Avatar
++1 on the r8 pro it's buttery smooth and I ran the rx8 for a year.
el Bourlando is offline
Old 03-10-2012 | 05:01 PM
  #844
Will aluminum chassis braces have a negative affect on the car? Also, what aluminum servo horn can I run on this buggy. The supplied horn cracked (dont know how) and the one I ran on my old buggy wasnt as tall as the one suplied with the kit.
Lapster v2 is offline
Old 03-10-2012 | 05:17 PM
  #845
Originally Posted by Lapster v2
Well, i took my buggy to the track last night and for the couple of packs that I ran through it I was very impressed. It turns so much better than my mugen did. However, I broke a rear chassis brace and my night was cut short. I have read that some people have done the same thing. Are aluminum braces the way to go?
Did it break near the battery/esc tray? You can dremel off the edge of the tray where it comes so close to the chassis brace. Should take care of breaking braces.
(thanks, Jeff, for the tip )
Square Wheels is offline
Old 03-10-2012 | 05:32 PM
  #846
It broke right below where it mounts on the gearbox. I dont think it contacted the speed battery/speed control tray.
Old 03-10-2012 | 05:50 PM
  #847
Don't know what to tell you aside from the tray mod. Haven't had any problems with the braces on either end.
Somebody posted a pic of their 8.2 with a Racers Edge servo horn that looked pretty sturdy.
Old 03-10-2012 | 06:46 PM
  #848
If you look really closely, the tray just barley contacts the chassis brace. Just Dremel down that little corner of the tray, it should alleviate your issue. Personally, I went with aluminum chassis braces front and rear, a BCE chassis, SS screw kit, and DE bumper/skid plates. As others have said, this buggy handles great. Better than my Mugen. But in the durability department, out of the box, Mugen blows Associated out of the water!
naterater is offline
Old 03-10-2012 | 06:56 PM
  #849
heavyjeffd's Avatar
That's where mine were breaking until I dremeled off that little corner on my battery tray. It was pushing on the brace.
heavyjeffd is offline
Old 03-10-2012 | 07:24 PM
  #850
Awesome, thanks for the tip guys! Is anyone actually running the stock servo horn?
Old 03-10-2012 | 07:42 PM
  #851
heavyjeffd's Avatar
I am believe it or not, I have an aluminum one for it, but this one is fine so I haven't replaced it. No problems yet.
Old 03-10-2012 | 07:45 PM
  #852
PTP Racing's Avatar
I have the new 8.2 Punisher and it more then clears my Protek 5600mah 4S
PTP Racing is offline
Old 03-10-2012 | 07:46 PM
  #853
Yes. Never had a problem with it.
I don't know how y'all are breaking all these parts. My 8.2 has had the hell beat out of it. Only thing that has broken is a wing mount after repeated hard hits and bent upper arms. BTW, anybody got a set of the new reinforced uppers yet?
About the only complaint I have is diffs leaking after a few weeks but I'm going to try some RTV sealant on the gaskets next rebuild.
  #854
PTP Racing's Avatar
Ive used the stock horns for years since the rc8 was first released. I only run aluminum on the truggy steering.
Old 03-10-2012 | 08:15 PM
  #855
Which aluminum horn do you have? It seems like there is a clearance issue with the horn that came with my servo that I was running after the stock horn broke.
