Team Associated RC8.2e Thread
#857
My stock servo horn didnt strip, a corner where it mounts to the servo cracked. I've never seen that happen, maybe its an aberration. I've also never run aluminum servo horns! I think I'll order an aluminum one if I can find a model that fits as well as the a plastic one. Are there any alternate plastic horns too?
#858
I still don't get why people run such enormous batteries in their buggies.
You only need to make 10 minutes, why not right the lightest battery you can rather than load it up with a bunch of unnecessary weight?
I run the 3700mah Reedy Wolfpack 4S's and easily make ~15 minutes on big tracks and it's about half a pound (if not more) lighter than that 6400.
#859
Running alum chassis braces takes away. Traction in the rear
Because there is no flex.. Those other kind are good the rod looking ones if u want to run other than the stock..
Also I run a ulum racers edge horn and it
Really needs to be longer so I can get full throw with
The steering,if u run it shortens up th throw because it hits on the servo link against the servo causing it to flex and strip ur horn over use and sometimes messing up your servo the stock one that comes with it is a tad longer but the plastic is weaker of course.. Ima gonna try and fine a ulum horn that is longer so I can get full lock myself..
#861
I have a question a bout diff fluids. I was running 5/7/3 in my buggy and it always seemed good. I have never tried another diff set up. My question is would 5 in the center make it handle better in the bumps? would it affect acceleration?
#862
You will lose some on power traction, because most of the power will end up going to the spinning front tires. Although the buggy wont launch as hard, it will track much straighter.
#863
I just started running the Ofna clamping style aluminum servo horns. They have the same length as the stock one but I needed to space my servo up to clear the radio tray with turnbuckle. Ofn10774
I never broke a stock horn but I did notice a lot of deflection in it when forcing the servo saver by hand. Yes that may help act as an additional "servo saver" but i prefer to use the actual servo saver for that. I also run a 7955 so broken servos are never a worry on my mind.
#864
The JQ Products aluminum servo arm and the VP Pro aluminum servo arms both work great. They are raised enough to clear the top of the rx box without having to shim up the servo, and are long enough to allow full throw without binding against the side of the servo.
Of the 2, I like the VP pro better. Its cheaper and looks better. LOL Both work perfectly though.
#865
There sure is a lot of knowledge in here! I guess I am going to order a stock servo horn and a long aluminum one. I'll get it sorted out!
New question... For the couple of packs I ran I was having trouble keeping the rear end planted under hard breaking. Is this an anti-squat issue? I dialed my breaking way down and it still did it. Any thoughts?
Is this is one? http://www.amainhobbies.com/product_...rvo-Arm-Futaba
#866
#868
The issue I ran into with any of the aftermarket aluminum servo horns was that the steering arm contacted the servo. You will need a slightly longer horn. I am going to order another plastic one as well as an aluminum one (http://www.amainhobbies.com/product_...rvo-Arm-Futaba). Im hoping my break was a fluke, if it breaks I will just put the aluminum one on.
I see you race at LCRC, that is an awesome track. I relocated to Houston and I sure am missing it!
#869
Hello Everybody. I put a post reply the other day and dont appear. Let`s try again. I am mounting the car and have a big problem wih the differentials because have leaks in the screws. I have change it 4 times and continue the same. Any idea ? I think i need to go to the shop to tell what happens.
Thanks in advance.
Thanks in advance.
19Likes
