SC10 4x4 Thread
where can i get them wheels? thanks
So I got my truck built again, and took it out to Gulf Coast Raceway Yesterday to attempt the infamous Quad and Triple with it. The track was in less than optimum shape. It was wet and grip was not optimal. However, I was able to consistently clear the quad without problems. The triple was also possible, even though not as easy as with the Losi. However, during racing nobody really attempts it as it is pretty inconsistent due to the long flight time. We typically only do it to gain time on a last resort basis and it's only like a 50% chance you will land right and actually gain time.
There are several things that I feel helped my truck out: For one, the 550 motor. For my PERSONAL preference, it makes the truck easier to drive on the big track. I like the extra weight of if and where it is. With new gearing on an SC4x 4.5, (14/58) with a Tekin RS Pro in dual mode the truck had almost the same top speed as the 4600, however with less punch. This translated into much easier throttle control, which in turn allowed me to run the truck at 6lbs 2oz. The lighter weight seemed to allow the truck to jump much better and longer too. The landings are far less harsh.
For drive I ran a clutch basket with HD pads. We tried our own version of a center diff, and while it felt good through the corners and rough sections, it suffered leading up to jumps, it felt like it was diffing out. It's almost like an 8th scale with too light of a center fluid/ empty center diff.
The clutch basket had much better forward drive and was a little loose on power. Nothing that was too bad though. However not as stable as the Losi truck.
Another thing that I think suited the track was light diff fluid. Running 3k rear 5k front. This is what I run on my SCTE, so I figured I would give it a shot. I still am not sure about it, have to run it in more, but so far I have liked it.
Now I am just waiting on a pinned top shaft to try that again. We'll see. At least the jumps are doable. I do think that part of the problem on the jump is that the right line to take is only about 3 ft wide. This is really hard to hit every time correctly on a track this size.
Above is a picture of the truck.
Shocks have nothing to do with in air adjustments which this truck lacks. you cannot get the nose up or bring the nose down at high speeds in the air, the Losi and the Durango do not have this problem. Its been proven by more than a few as well as at least two Factory AE drivers that claim the same thing. I happen to be pretty decent at shock adjustments and spend more than 5 hours at tracks during the week. I dont know everything but I know alot, my truck is better at it than before but still not near good enough.
Low speed approach 30' triples are not a problem its the 40mph 36' jumps that are an issue and not everyone has access to these types of tracks and I didnt until recently.
I didn't find my Losi to correct all great in the air either. The solution imho is so that your car doesn't jump akward at take off so you don't need to make drastic corrections.
I am not claiming to have the answer, but watching some of the fast locals, they don't seem to have the issue with making larger jumps. In fact, one of the reasons I ditched the Losi was watching how great the sc10 seemed to handle in the hands of a good driver.
I found that I liked the white front springs on the rear even more after we chatted but with the two stage pistons I had too much rebound but it was better everywhere else but landing the big jumps. Easy fix though. It did jump considerably better. We have a new layout now and we will see if it works on the new layout too.
Read closer in Cristian's post and he says he cannot do it with any consistency. nobody said we couldnt make the jump ever, just not consistent.......
The wheels on my truck are the Avid RC Prototypes. At least one person noticed! :P They are +3 offset and have a couple of other really neat features that will make the glue job a lot easier. They will be available in black only at first though, and should be available in like a month according to my sources at Avid. They are modeled after KMC Rockstar wheels, by far the best looking and best wheels I have tested for SC trucks to date. The attention to detail makes them better.
I agree that the Losi doesn't really have better air control. Once that nose is down or up, there is no way to move it. The air pushes on the body too hard and loosing control of the truck in the air pretty much is a death sentence with an SC. 2WD Trucks are even worse!
WC, yes, the jump is not easy, and I do have to be lined up better because I have less power in this truck, but the jumps are certainly doable. Lap times, I did not get to compare, but I still don't feel like I have the same amount of corner speed as the Losi, but in some jumps I felt like it was better.
Note: Corner speed is not the same thing as steering or rotation.
The triple was not consistent, but the Quad is. In all fairness, the triple is not consistent with any truck. Like I said, it is like a 3 out 5 success rate. But with the AE truck it is harder mostly due to lack of power.
well if you got any extra and wanna make some cash PM me
they look nice if you ask me
I can't speak for Mantis, but I ran the ceramic diff balls myself and feel like they lack "grip" Our prototype ball diff used 16 balls and pinned hubs and it still would slip. The trucks are just so heavy and powerful that when the power gets down, it typically slips, especially going over ruts. This made it hard to accelerate going up to big jumps. In the corners though, it was a dream.
WC, I don't think a different belt would make much of a difference. On the corner speed, something has to be done to equalize power so that the gas can be mashed and the truck can shoot forward, rather than step out. I have a feeling that a center gear diff, even if it is not fluid filled, and a higher rear roll center would make the truck better.
I had the same results and ended up going with 10 4mm balls instead of 12 3mm and it does not slip.
Just need an honest opinion. Do the saddle packs make that much of a difference that it is s must have. Or is the stick pack good enough for a club racer. Just want to know if it is worth the investment???
I've actually decided a couple things.
- I don't have a workshop or tools anymore to start tinkering with rates, and counter rotating this and that.
- I don't have any more free money after spending it all on this Truck.
I am going to leave my sc10 4x4 on the wall until either 1. They fix it. or 2. They bring out the platform we "need". It will remain my PRCR indoor Truck. I am going to start driving my LCG tuned Slash4x4 again. (It drives better outside than the Sc10 4x4) I'm not giving up on it all the way, but i'm tired of it right now. I think a break from it will allow the patience to return. I love my SC10 4x4, but we're going to see other people for a while.
5Likes
