SC10 4x4 Thread
I know there were several sc10 4x4's in that race at loganville, 4 or more of them. The winner was driving mine thats how I know, also TQ. I did not know I would be able to see a vid mostly of my truck all by itself. There are alot of good drivers in this area, not me lol. The guy does some good vids!
Very curious what you come up with. Seems like the middle hole should be original. Then you could go more or less aggressive depending on needs.
Okay. Here's my Method for quick 5 minute breakdowns to get to the diffs. Hope this helps some of you guys.
Quick Diff Removal Guide:
Step 1
Step 2
Step 3
Step 4
Step 5
You may try this and call me crazy, but once you can easily pop on and off those CVAs. This is literally a 5 minute diff removal. And you don't have parts strung out all over. Only 4 pieces. or "chunks" I should say. Lemme know if you guys have questions.
I got lazy and didn't want to do a video. Mostly because I have no one to hold the Cellphone Camera.
Step 1
Step 2
Step 3
Step 4
Step 5
Run a HD pad for the front and 2 standars in the basket for the rear. Start with the nut flush with the end of the shaft. Unless your spring is toasted, then it's anybodys guess.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 5
Glad to do this stuff. I can do any other tutorials anyone needs too. I'm very proficient with Photoshop, and have no problem tearing my truck apart if a picture solves someone's confusion.
just doing some maintenance on the truck before the MI state champs this weekend and trying new products
I made my truck transmission develop a clicking sound front and rear
how i did this was on the installation of the idler gear and main gear diff all you need to do is have one facing the wrong way ie
The following number sequence is how your gears should be installed in the gear case. if you don't install them right it will make a clicking noise because it won't aline where it is supposed to. ( won't be as free running as it should be)
1 top shaft in first
2 main gear diff with the flange facing in (same side as top shaft)
3 idler gear with the flange facing out (on the same side as the other gears )
this is something you might want to check and make sure you have them right
loganville is a good one ...you should come over and race with us sometime indoors
http://www.youtube.com/watch?v=DeuHTAHh3Io
5Likes
