Like Tree1Likes
Sirio engines thread
Old 08-12-2004 | 12:55 PM
  #511
EdwardN's Avatar
Default Re: any star motor offiliates out here??
Originally posted by endler
if i have to actually glue my sleeve in for it to run right....what good is this engine then... ive been pulling my hair out with this thing for awhile and after a new piston sleeve button wrist pin and a proper bench break in the thing still dont run right?? i was starting to re-evaluate my tuning skills?? since this thread has people offiliated with star motors in it.....what would you say ive spent much$$$$$ and i have yet to see any return but problems!! i want to ship this thing back!! ive had a rb c3 rody(three thumbs up!!) and a rossi black magic ( another three thumbs up!!) still have em and they still run like a top...this motor i bought beacause i wanted to put a new engine in my x5 because i bought the x5 new...last year it cost me 3 points races and this year this last past sunday it cost me one because it stalled for no reason!! i dont want it anymore...
Don't get disappointed right away. I do understand your position, but as I sad before, every manufacturer who will try make AAC on conventional design, will sooner or later face this problem. We pass this problem years ago ( 1980's) and since that we don't use AAC ( I know for fact that one of my P/S set out of AAC been use by very high ranked racer and it was very successfully, he won a lot of competitions in Europe and in Asia, but sleeve was glued to crancase) on conventional design. I might be able to help later, but at this point I have nothing to offer for Sirio engines.
Edward
EdwardN is offline
Old 08-12-2004 | 02:07 PM
  #512
hmmm is that why you new engine has da sleeve intrgrated with the block?
R1ceboy is offline
Old 08-12-2004 | 02:33 PM
  #513
EdwardN's Avatar
Yep. AAC construction has realy good materials properties, but because of issue explaned before and cooling rates, we went to our new design. On top of it there is a lot of machine work is eliminated ( milling of the ports-very expencive work). Also a lot of racers had faced problem when dividers between ports are getting craked due to the material thikness, so we eliminated one more place where device can have failure.
EdwardN is offline
Old 08-12-2004 | 09:38 PM
  #514
what if i dont want to glue my sleeve in??? and i shouldnt have to for it to work?? but if i gotta do it i guess i will??
endler is offline
Old 08-12-2004 | 11:31 PM
  #515
EdwardN's Avatar
It is my sugestion based on previuse expirience and experimants done lately. i can't tell you what you have to do, I just sharing my knowlodge. But ones agin if you glue sleeve in case, you will naver be able to take it out. Not to many peole can afford it. to loose crancase after P/S set is gone, so please take this to considiration. To change conrd will be pain of but too, and I am sure not too many people knows how to change conrod wihout taking out P/S set, but it is possible and it is actualy very simple basic procedure. SO please before you make up your mind make sure you wieght all +++ and ---.
Edward
EdwardN is offline
Old 08-14-2004 | 06:16 PM
  #516
Registered User
Default Help
Hi, I bought my kyosho V-one RRR that come with Sirio S12 TRP-I Evo2 engine. The instruction are in Japanese. Do any of you have it in english version? Please send it to me. Thanks
Aku-Man is offline
Old 08-14-2004 | 07:10 PM
  #517
afm's Avatar
afm
Default Re: Help
You mean instructions for the engine??? Go to www.teamtrinity.com there you'll find Sirio's bulletins and under tips youll find some good advice on tuning nitro engines.
For the car you better go to the Kyosho V one R thread in this forum, several guys are discussing the bulid up and set up of your model there.
AFM
afm is offline
Old 08-14-2004 | 07:14 PM
  #518
Registered User
Yeah, I just need the engine instruction. I'll check at trinity. Thanks
Aku-Man is offline
Old 08-14-2004 | 07:27 PM
  #519
afm's Avatar
afm
Default BREAK IN PROCESS
THIS YOU WON'T FIND AT RINITY'S SITE
This is what Andrea Rossi from Sirio says for Break-In
AFM
This is the correct Break-In procedure for the Sirio S12 Evo2
1.- One 125CC (1) tank in the bench at WOT with very rich setting of HSN, avoiding it to go on 4 stroke.
COOL DOWN
2.- Three (3) tanks on the track at WOT on the main straight with very rich setting of HSN, as if the engine wants to die, and tuning the HSN at the end of third tank to get almost full power.
COOL DOWN AFTER EVERY TANK
3.- For 20% Nitro, use .20 head shim and N° 7 Glow plug.
After that, the engine will give more power every new tank.
Which means that Breaking-In Sirios, should be done with more or less 300 to 500cc of fuel.
Andrea Rossi
Star Motor Corp. (SIRIO)
afm is offline
Old 08-14-2004 | 07:31 PM
  #520
Registered User
What is the best glow plug to use with this engine?
Aku-Man is offline
Old 08-14-2004 | 07:34 PM
  #521
afm's Avatar
afm
READ MY LAST POST
AFM
afm is offline
Old 08-14-2004 | 07:37 PM
  #522
Registered User
But I see there's also hot and cold plug. Which to use? Sorry, I'm new to nitro.
Aku-Man is offline
Old 08-14-2004 | 07:44 PM
  #523
afm's Avatar
afm
IF YOUR ENGINE CAME WITH A TURBO HEAD
SIRIO S001720127 OR NOVAROSSI C7TGF
IF YOUR ENGINE CAME WITH STANDARD HEAD
NOVAROSSI C7S OR O'DONNELL O77
AFM
afm is offline
Old 08-14-2004 | 07:46 PM
  #524
Registered User
I see the Japanese manual (not really understand it). This engine can use part# s1720025~s1720128 glow plug.
s1720025~s1720028 are s5~8 Hot
s1720125~s1720128 are s5~8 Cold
I fould out they are turbo plug? Isn't this engine use standard plug?
Aku-Man is offline
Old 08-14-2004 | 07:49 PM
  #525
Registered User
How can I know my head is turbo or non-turbo?
Aku-Man is offline
