RC10B4.1 FT/WC
no. they are two different things. The one plugged into the receiver is for your servo. The one soldered to the speed control is for the throttle. They both do similar things, but independantly of each other. Make sure you are getting the right kind and putting it in the right spot. And you can't just go by what everyone else says because it's totally dependant on your electronics and what combination of stuff you chose. For me, I have the SXX with it's power cap and then I use a Futaba servo and Spektrum SR3000 rec. That Servo will shut my car off if I don't use a cap on the receiver as well.
Hope this helps.
This is the one I have to put into my buggy Radio Post 1005
http://www.trick-parts.com/product_p/rp1005m.htm
Hi Guys,
I am about to build the shocks for my new b4.1 Worlds kit, is there anything I should know?
It's my first off road kit and me and shocks don't go well together, I am always struggling on my on road cars.
Nathan
Nathan
Let the O-rings soak in Green Slime for a little while. Pre thread the bleeder screws.
I see some plug into the Rx and others solder onto the ESC do they do the same thing? Sorry new to 1/10th never had to deal with this in 1/8th E
