RC10B4.1 FT/WC
Old 02-10-2012 | 02:33 PM
  #11191
DaveW's Avatar
Originally Posted by Littlejohn Dsgn
Is there a benifit to running more? I see some places call it a boost pack or something along those lines.
Only for hot motors... a 17.5 doesnt really qualify.
DaveW is offline
Old 02-10-2012 | 02:44 PM
  #11192
Littlejohn Dsgn's Avatar
Ok cool, single it is then I see some plug into the Rx and others solder onto the ESC do they do the same thing? Sorry new to 1/10th never had to deal with this in 1/8th E
Littlejohn Dsgn is offline
Old 02-10-2012 | 02:50 PM
  #11193
no. they are two different things. The one plugged into the receiver is for your servo. The one soldered to the speed control is for the throttle. They both do similar things, but independantly of each other. Make sure you are getting the right kind and putting it in the right spot. And you can't just go by what everyone else says because it's totally dependant on your electronics and what combination of stuff you chose. For me, I have the SXX with it's power cap and then I use a Futaba servo and Spektrum SR3000 rec. That Servo will shut my car off if I don't use a cap on the receiver as well.
Bob Barry is offline
Old 02-10-2012 | 02:52 PM
  #11194
07Forester's Avatar
I'm sure this was posted before, I've searched and couldn't find a definite answer.
I have a b4.1 rtr brushless. Can I do the Losi bb spring changeover on those?
07Forester is offline
Old 02-10-2012 | 03:03 PM
  #11195
yes but to be honest, it won't benefit you much. The single biggest upgrade you can make to the car is the +8mm chassis. If you have that, then drive the car the way it is until you feel you have gotten your money's worth out of it and then buy a Worlds Car. It will be cheaper than buying all the stuff you need to upgrade your RTR. If you don't have the +8 chassis, then consider getting it. Figure it will cost you roughly 45 for the conversion and then 20ish for a body. AGAIN... I would put that money towards the new worlds kit first though.
Hope this helps.
Old 02-10-2012 | 04:13 PM
  #11196
JEFFs SC10's Avatar
I know this is a preference of what servo see you guys normally use
JEFFs SC10 is offline
Old 02-10-2012 | 04:29 PM
  #11197
Spektrum 6040. I like a fast servo in everything, I'm one of those old carpet guys that wait till the last possible moment to turn. So I need it to react when I say so..
DHMOTORSPORTS is offline
Old 02-10-2012 | 04:47 PM
  #11198
bilster44's Avatar
Futaba BLS-451
bilster44 is offline
Old 02-10-2012 | 04:57 PM
  #11199
This is the one I have to put into my buggy Radio Post 1005
http://www.trick-parts.com/product_p/rp1005m.htm
Old 02-10-2012 | 05:38 PM
  #11200
NR's Avatar
NR
Default Shocks
Hi Guys,
I am about to build the shocks for my new b4.1 Worlds kit, is there anything I should know?
It's my first off road kit and me and shocks don't go well together, I am always struggling on my on road cars.
Nathan
NR is offline
Old 02-10-2012 | 05:45 PM
  #11201
Kurt04's Avatar
Originally Posted by NR
Hi Guys,
Nathan
Let the O-rings soak in Green Slime for a little while. Pre thread the bleeder screws.
Kurt04 is offline
Old 02-10-2012 | 05:56 PM
  #11202
Trevor Williams's Avatar
R/C Tech Elite Member
xp1313
Trevor Williams is offline
Old 02-10-2012 | 06:12 PM
  #11203
TJMac's Avatar
Originally Posted by t.mathewson
Can I fix this? How??
Graves in Orlando sells the crimping tool for servo plugs. I'm sure others sell it as well, i just know Graves does because I almost bought one there.
TJMac is offline
Old 02-10-2012 | 06:52 PM
  #11204
YankeeFan123's Avatar
Originally Posted by Trevor Williams
xp1313
+1
YankeeFan123 is offline
Old 02-10-2012 | 07:03 PM
  #11205
ANiznik's Avatar
Originally Posted by bilster44
Futaba BLS-451
+1, very good servo!
ANiznik is offline
