RC10B4.1 FT/WC
Old 01-12-2012, 04:38 PM
  #9691
idrummerboy13's Avatar
Trader Rating: 15 (100%+)
Originally Posted by T-BirdJunkie
Are the Bomb1 inserts discontinued? TRITK1511...nowhere to be found, distributor-wise.
run moldeds
idrummerboy13 is offline
Old 01-12-2012, 04:41 PM
  #9692
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by idrummerboy13
run moldeds
That's great for indoor.
T-BirdJunkie is offline
Old 01-12-2012, 05:20 PM
  #9693
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Originally Posted by derekbsmith
on some of the setup sheets, the racers have 2mm spacer listed on bump steer.
is this bump-steer location the place where the turnbuckle connects that control toe-in? or?
I am going to say yes, out by the wheel on the steering knuckle.
Kraig is offline
Old 01-12-2012, 06:20 PM
  #9694
B.A. Racer's Avatar
ok i did the hex and the rears work perfectly fine...but when i tighten the fronts down they bind and dont move..the wheel sticks..even if the nut if only 1 turn on you can feel it binding..they arent associated wheels but it doesnt seem like the whell is it..and the bearings are brand new
B.A. Racer is offline
Old 01-12-2012, 06:32 PM
  #9695
brent701's Avatar
Trader Rating: 8 (90%+)
what parts dd you replace to add the hex and which hex?
brent701 is offline
Old 01-12-2012, 06:41 PM
  #9696
B.A. Racer's Avatar
b4 wheel hex axles 7496 the steering block 9880 and im just using associated plastic hexes right now just cuz i got them for free at the shop
Old 01-12-2012, 06:43 PM
  #9697
big chris's Avatar
Trader Rating: 51 (100%+)
I also have a hex conversion question. Will my RB5 wheels fronts and rears work? Amain says 22 compatible wheels?
And its just these parts for the F/R conversion right?
ASC 7496,7497,9880
big chris is offline
Old 01-12-2012, 06:57 PM
  #9698
brent701's Avatar
What rims? I have found some rims you can't tighten the axle nut all the way down it will bind the bearings. I am not sure which ones they were though. I used a set from a buddy at the track and they did this to my buggy as well in the front
ASC 7496,7497,9880
Yes, also add #4449. They are the nuts that hold the ball stud to the RS steering blocks. They don't just screw into the blocks.
You can also use Jconcepts 2091 for the rear only.
brent701 is offline
Old 01-12-2012, 07:02 PM
  #9699
B.A. Racer's Avatar
they are older team C rims..yea that is the only thing i can think of right now.
Old 01-12-2012, 07:46 PM
  #9700
SkarTisu's Avatar
Do you have a shim between the axle pin and the outer bearing in the hub?
SkarTisu is offline
Old 01-12-2012, 07:48 PM
  #9701
B.A. Racer's Avatar
yes i do
Old 01-12-2012, 08:30 PM
  #9702
Trader Rating: 19 (100%+)
Did you use the "C" clip between the bearings? I believe it acts like a crush tube in the rear hub.
deftones4012 is offline
Old 01-12-2012, 09:10 PM
  #9703
Trader Rating: 16 (100%+)
They are the best open cell foams I have ever tried. Always consistant package to package and last a really long time. Amain has them listed to be back in stock on the 22
I also learned when running the plastic hexes on the RB5 If you tighten the front wheels down to hard it would bind. Same problem with the plastic B4.1 hexes/ Fixed that when I switched to aluminum clamp hexes.
Zach Phillips is offline
Old 01-12-2012, 09:12 PM
  #9704
Timmahhh's Avatar
I thought I'd post up a couple pictures of the new finnisher.
Attached Thumbnails RC10B4.1 FT/WC-front.jpg   RC10B4.1 FT/WC-side.jpg
Timmahhh is offline
Old 01-12-2012, 09:31 PM
  #9705
Teambcw's Avatar
Trader Rating: 28 (100%+)
they will be available soon... many things are back ordered right now from all manufactures. I spoke to them 2 days ago and they are cutting and packaging foam as we speak... should be in stores in a week... I know this foam works way better then molded at my local indoor track.
Teambcw is offline
