Team Associated TC6 Thread >
Like Tree20Likes
Old 02-09-2012, 01:04 PM
  #5686
Originally Posted by acerracing
We are proud to announce the release of our Team Associated TC6.1 Factory Team kit with a full set of ACER Racing Ceramic Ball Bearings, Ceramic Differential Balls and Ceramic Thrust balls as well as a bottle of our SIN 100% synthetic bearing oil, for only $397.99! Check out our growing stock of high performance RC cars that we have bundled with the #1 performance upgrade for your ride: our Ceramic Nitride Pro Series ball bearings and diff balls.
Why does it come with diff/thrust balls, when the 6.1 comes with a gear diff?
-Mike
grippgoat is offline
Old 02-09-2012, 02:59 PM
  #5687
Dog Bone's Avatar
That's a huge amount of money to spend on bearings....
Dog Bone is offline
Old 02-09-2012, 03:57 PM
  #5688
Madulla's Avatar
It comes with a car Ken
Madulla is offline
Old 02-09-2012, 04:06 PM
  #5689
heh
When drive modified I just need normal bearing
Cheap ones, change each event.
Forget ceramics, they will not give you 0.1sec per lap, 0.1sec per lap give more training and learning how to set car
Regards!
M.Abramowicz is offline
Old 02-09-2012, 05:49 PM
  #5690
AE-Reedy
Originally Posted by Steve S
The instructions are a bit ambiguous as to where exactly on the arm you measure with the droop gauge, and the included gauge isn't the most precise thing in the world. That said, my best attempt to follow the kit setup gave me 2mm up-travel in the rear and 1.5mm in the front.
If you look close there is a specific flat area by the outer pin that is where you should measure droop. I don't have any arms around right now or I would photo it.
Sean Cochran is offline
Old 02-09-2012, 05:50 PM
  #5691
AE-Reedy
Originally Posted by bhambrent
Same here
Bring back the slipper spool!!
It never went any where!
Old 02-09-2012, 05:58 PM
  #5692
AeRacer805's Avatar
+1
AeRacer805 is offline
Old 02-09-2012, 07:05 PM
  #5693
Dog Bone's Avatar
D'oh, missed that . That's an all-right deal then
Dog Bone is offline
Old 02-09-2012, 07:19 PM
  #5694
bhambrent's Avatar
Trader Rating: 11 (100%+)
Originally Posted by AeRacer805
+1
It will not fit in a tc6.1.
bhambrent is offline
Old 02-09-2012, 09:52 PM
  #5695
Trader Rating: 86 (100%+)
i have a gear diff in front.
should i use 300k or 500k diff fluid?
putty dont seem works for me
littlealex is offline
Old 02-09-2012, 10:23 PM
  #5696
The Evicerator
I've had a slipper spool fit just fine in my 6.1...
Steve Weiss is offline
Old 02-09-2012, 10:42 PM
  #5697
SlideMasteR's Avatar
there has been no change in the bulkheads so there is no reason it shouldn't fit
SlideMasteR is offline
Old 02-10-2012, 01:15 AM
  #5698
Anyone got any tips for freeing up the droop screws? Mine are super tight. It makes adjusting droop a bit of a chore. It flings the car off the blocks.
-Mike
Old 02-10-2012, 01:51 AM
  #5699
piper48
Guest
Posts: n/a
Chase the threads with an M4 tap.
Old 02-10-2012, 05:37 AM
  #5700
I have used kyosho 500k & it worked verry well.
Shortbusallstar is offline
