Team Associated TC6 Thread
#5671
Hi guys!
I am a pretty experienced Nitro driver but I just entered the Electric class and bought a Team Associated TC6.1 car.
I have a question regarding the setup of the car.
According to the basic setup you should have 5mm Ride Height and 6mm Droop at the front and 5mm Droop at the rear.
If I use these settings with my Sweep 32 tyres (I don't know if different tyres have different diameter in the electric class ) then the droop screws almost touch the chassis and there is really small up-travel for the suspension.
If I lift the car the droop screws immediately touch the chassis.
Is this normal or I am doing something wrong?
Thanks a lot!
Thanks a lot!
#5672
You don't check droop with tires on. You can also unmount your shocks for a better setting. The kit droop gauge is a bit unprecise, but it's OK if you use it for all the 4 sides
#5673
By guys. does anyone knows were can I buy the TC6 Spool Outdrive. I can't seem to find them anywhere. Thank you
#5674
Dug around but could not find anything regarding this. Given the apparent planetary wide shortage of 6.1 Caster and Steering blocks, I wondered what would be required to run the TC6 blocks on a TC6.1 ? I'm sure I'm not alone, but again could not find anything. Thanks !
#5675
#5676
#5677
I always measure the droop without the tires, without the shocks and without the anti-roll bars.
I just mentioned the tires because if other tires have larger diameter then you can have 6mm droop, 5mm ride height but more up-travel on the suspension.
#5678
broke my 6.1 front out drive. where can i find this part?
#5682
Guys, can you help me track down the following info from AE drivers at Snowbirds? I'm trying to complete the information here: http://rcprogear.com/tagged/snowbirds12
Class:
Name:
Chassis:
Motor (Turns):
ESC:
Tires:
Battery:
Body:
Radio:
Class:
Name:
Chassis:
Motor (Turns):
ESC:
Tires:
Battery:
Body:
Radio:
#5683
Associated TC6.1 kit with a full set of ACER Racing Ceramic Bearings and Balls
We are proud to announce the release of our Team Associated TC6.1 Factory Team kit with a full set of ACER Racing Ceramic Ball Bearings, Ceramic Differential Balls and Ceramic Thrust balls as well as a bottle of our SIN 100% synthetic bearing oil, for only $397.99! Check out our growing stock of high performance RC cars that we have bundled with the #1 performance upgrade for your ride: our Ceramic Nitride Pro Series ball bearings and diff balls.
#5684
Class: USVTA
Chassis: Team Associated TC6.1
Motor (Turns): NOVAK 25.5
ESC: NOVAK
Tires: HPI
Battery: REEDY 5000
Body: HPI '68 Camaro
Radio: Futaba 4PKS
Class: USVTA
ESC: NOVAK
Tires: HPI
Battery: REEDY 5000
Radio: Futaba 4PKS
#5685
After a second look...... good deal!!!
