Like Tree18Likes
Xray NT1
Old 01-08-2012 | 02:26 PM
  #6226
djiewie's Avatar
Originally Posted by Condor Speed
Hello, I ran my Nt1 all season last year with the high dynamic clutch,,,The clutch still works very good but when do you know if the the clutch bell needs to be replace??
when the bearing gets too much play in the clutchbell , you should replace it.
When you start ripping the spurs it tells you to check the play. i`ve destroyed 3 spurs before i noticed the play, after replacing that it was good.
Otherwise run it for ever.
djiewie is offline
Old 01-18-2012 | 07:31 AM
  #6227
Company Representative
Hi Guys,
I am blowing out my remaining stock of all NT1 parts. ( No kits left)
50-60% off retail on all stock.. The more you buy the more you save.
I will be creating a price list and updating our webstore. your interested in a pricelist please PM me this will be the quickest way.
Shipping wil be sent via post and payment will be paypal.
Now is your chance to stock up on all parts at a fraction of retail price.
Korgae is offline
Old 01-22-2012 | 01:07 PM
  #6228
staikosn1's Avatar
Default Thats my beauty!!!!
I used CSO brake disk, serpent brake springs!
I dont know if they work with ferodo pads when the material is used!
Attached Thumbnails Xray NT1-img00187-20120122-2155.jpg   Xray NT1-img00188-20120122-2155.jpg
staikosn1 is offline
Old 01-22-2012 | 01:12 PM
  #6229
staikosn1's Avatar
Default My new engine
My new engine-pipe set....
Attached Thumbnails Xray NT1-img00189-20120122-2156.jpg   Xray NT1-img00190-20120122-2156.jpg
Old 01-22-2012 | 01:15 PM
  #6230
staikosn1's Avatar
Attached Thumbnails Xray NT1-img00191-20120122-2157.jpg   Xray NT1-img00192-20120122-2157.jpg   Xray NT1-img00193-20120122-2157.jpg   Xray NT1-img00194-20120122-2158.jpg
Old 01-22-2012 | 01:19 PM
  #6231
staikosn1's Avatar
Any opinion is accepted for update the car!!
Old 01-22-2012 | 01:48 PM
  #6232
GREGORY!'s Avatar
your car niko is teza!
the only update i could see is aluminium hexagons in the wheels.
GREGORY! is offline
Old 02-02-2012 | 03:46 AM
  #6233
rc-goods's Avatar
Default Zero Force NT 1 Bearing Set (16 pcs )
www.rcgoods.com
rc-goods is offline
Old 02-08-2012 | 11:48 PM
  #6234
Default nt1 parts interchangable
hi im looking at up grading my on road chassis, can anyone tell me if i was to get say a 2008 nt1 could the upper and lower chassis be replaced with newer model ones, around 2010 / 2011. im on a bit of a budget but would like to get an xray and posibley up date the chassis as money alows. thanks to anyone who can help out.
mike hunter is offline
Old 02-09-2012 | 04:48 AM
  #6235
Riketsu's Avatar
Yes.
You can buy a 2008 nt1 and upgrade the chassis and radio plate to even 2012 specs.
The problem with the 2008 chassis (or any pre-2009 NT1 chassis) is the plastics (arms/hubs) were too soft.
I would try to get at least 2009+ chassis where it should have at least front CVDs and then upgrade the chassis and radio plate to 2012 specs.
Riketsu is offline
Old 02-09-2012 | 07:18 AM
  #6236
esckalayd's Avatar
Default Rear Tire Wear
I have been scratching my head at this one. What are some reasons that i would be tearing through rear tires. Meaning loosing about 2mm per 5 min qualifier. I am geared 16/60 23/55 right now and my setup is about 1-2 degree rear toe and 2-3 degree camber. I am getting the right conical wear from the rear setup but i am tearing through rear tires. Is there something else i should look at or is this just normal for xray. My friend has the new KM and same track, same qualifying time, with almost the same gear ratios, he only gets about 1mm wear. Forgot to mention, normal shores depending on traction i run a 35F/37R or 37F/40R. Any ideas?
esckalayd is offline
Old 02-09-2012 | 07:29 AM
  #6237
Riketsu's Avatar
There are many things that factor in tire wear. From track conditions, shores, different tire brands, throttle control (and hard braking), clutch settings and driving style.
Try going 17T on the clutch for a less explosive take-off.
Riketsu is offline
Old 02-09-2012 | 07:35 AM
  #6238
esckalayd's Avatar
the only variable between us is going to be clutch settings and driving style. Same tires manufacturer, same track, same shore. I will throw the 17 back on and see if that helps at all.
Old 02-09-2012 | 07:45 AM
  #6239
SOLOARTIST 702's Avatar
Also check what middle side pulley you have on could cause excessive rear tire wear also
SOLOARTIST 702 is offline
Old 02-09-2012 | 08:48 AM
  #6240
esckalayd's Avatar
I have the 25T pulley on the side.
