Serpent 811E Buggy Thread >
Like Tree5Likes
Old 02-06-2012 | 07:41 PM
  #1396
Originally Posted by puttekula
Some attempts to simplify my Snake. A special bracket for the servo/esc is in process.
Any luck trying a different layout? I pulled my stuff out this weekend and wasn't able to get everything to fit laying the servo flat. Esc is too big and mounting it on top of the servo seemed to raise the cg too much.
400units is offline
Old 02-06-2012 | 09:36 PM
  #1397
No, theres no luck with different layout but the CG gets lower with this layout. And things gets much easier to reach in that area. I have changed some steel parts for aluminum and titan parts. And that together with reducing/cleaning some unnecessary plastic stuff will hopefully put the car in the sub 3,5kg area.
puttekula is offline
Old 02-06-2012 | 11:35 PM
  #1398
porkchop's Avatar
i have told you guys 900 times just run the stuff and it break in
porkchop is offline
Old 02-07-2012 | 04:51 AM
  #1399
Originally Posted by BigRon
LOL!
Well for starters are you racing indoors or out? If indoors on a packed clay track, start with Chops setup. That's the setup I'm currently running with the exception to 50wt (Losi) in the front shocks and I'm running -2.5° camber in the rear. That's working out real well for me. The tracks I'm racing on right now have high speed sweepers at the end of the straights. This setup gives me just enough rear side bite to maintain a faster speed than the other cars. Give it a try. Also depending on the size of the track use either a 15t or 16t with the 2050. I'm using throttle profile 2 with 10° timing running 60c 2s lipos. Hope this helps.
theres the youtube link?
HotBodiesVe8Boy is offline
Old 02-07-2012 | 06:16 AM
  #1400
Old 02-07-2012 | 06:18 AM
  #1401
I'm working on some setups to make the steering feel more linear. At the moment with my current setup, the buggy seems too sensative and a little twitchy at speed. I already played with the steering expo. Anyone have any setups that make the steering feel more linear? Currently running option 3 ackerman and aftermarket alum servo arm with linkage mounted in outside hole on alum servo arm. I'm thinking of moving the linkage in one hole on the servo arm. Any idea? Also, here is a picture of how I mounted my esc. I've been seeing everyone mount their esc with the wires facing the rear of the car. My reason for changing it was so that the esc adjustment buttons and sensor wire are easily accessed on the outside of the buggy. A nice bonus is that the wires form a small shield to perhaps prevent any rocks from getting lodged in the esc fan. I know some of you might think that the wires will prevent air flow, but they are not laying on top of the esc and my fan hardly ever turns on anyway. I haven't seen any increase in heat production.
Attached Thumbnails Serpent 811E Buggy Thread-p1010383.jpg   Serpent 811E Buggy Thread-p1010384.jpg
400units is offline
Old 02-07-2012 | 06:41 AM
  #1402
Father lecturing his children. If I have to tell you one more time....
400units is offline
Old 02-07-2012 | 06:51 AM
  #1403
what would this car be like in characteristic wise compared to a hb ve8?
Old 02-07-2012 | 07:16 AM
  #1404
Frank L's Avatar
ok if your happy with it i let go but just looks like moves to much and is making the car losse to me
Awe come on I'll always try something new. The track turned to ice that day and all cars were sliding around. The clay dried out. But like I said 2 pages ago send your shock setup over. I'm always wanting to try new things.
Frank L is offline
Old 02-07-2012 | 08:30 AM
  #1405
tony montana's Avatar
I built many 1/8 buggies and have never seen the drive train his tight before.
tony montana is offline
Old 02-07-2012 | 10:15 AM
  #1406
Yes, then it has to be the 901:th time. And we dont want that to happen...
But I still dont know what he meant.
Old 02-07-2012 | 10:52 AM
  #1407
atl darrick's Avatar
he was meaning that if you have notchyness in the diffs when building the kit, that it is normal and will break in. he has told people 900 times lol
atl darrick is offline
Old 02-07-2012 | 12:52 PM
  #1408
Hmm, that was one of my thoughts as well. But as I never had any problems with it, I am still not sure.....
Old 02-07-2012 | 02:00 PM
  #1409
porkchop's Avatar
i am sure after this weekend you can pm kik and ask him or maybe i can talk him into posting something
porkchop is offline
Old 02-07-2012 | 02:13 PM
  #1410
dtr's Avatar
dtr
Hi,
Could somebody please post a four-scale weight distribution measurement? This is the nicest buggy I've seen, but I'm still afraid of how hard it is to balance the motor weight.
dtr is offline
