RC10T4.1 Thread.
#452
I think part of my issue is that everything I know about gearing comes from 1:1 auto racing. I know that in my full size cars I feel a massive difference in punch and top speed going from 4.10 to 3.73. I have to retrain my thought process when thinking RC.
#453
long story short lol
#454
trying to paraphrase it here, but from what I was told by the late Big Jim, one of the premier motor men of time, electric motors make there peak torque at near 0 rpm. They don't have to *rev up* like a nitro engine. Based on that, he said that when I went with a bigger pinion gear, I would actually see an increase in torque. (now, this was before the whole boosting craze, so keep that in mind).
I gave his advise a try and he was right. I had a lot more punch. You just have to balance it with the temps you see on the motor, etc.
#455
http://www.teamassociated.com/pdf/ca...-preflight.pdf
Question for everyone else, that same page of the manual suggests the starting gearing for a 3300kv motor to be 18/87, which is what the truck comes with, having an FDR of 12.57:1.
A few lines above its says that a 13.5t using the same exact gears would give an FDR of 7.80:1.
Time and again I hear the 3300kv compared to a 13.5t, how on earth could the FDR numbers be WORLDS apart using the same gears?
#457
How important is it to ditch the servo saver in favor of like the new Avid Steering Bellcrank? I am a fairly serious racer that’s been out of 1/10th for a while (last 2 years I have focused on 1/8th) I had a B4 and never had issues with steering.
Just wondering if its one of those things that’s a must or something that’s more of a gotta have it because "in theory" it will help.
#458
#464
Also found out yesterday that the 3300kv motor has ZERO top end now that I had a good straight to try it on. I've never fealt a motor fall so flat up top. It accelerates like a bat out of hell, then just stops accelerating completely. I'm thinking about swapping in the 3900kv. Opinions? (please refrain from telling me to buy a new esc motor combo, I want plug and play and only a bit more top speed. The 3300 is actually perfect for the tight indoor track I run, I'd like to carry two motors of different Kv for different tracks)
You are maxing out the motor halfway down the straight, Maxing out the motor is a no no. You need the motor to max out about 3/4 the straight, or closer to the turn. I'm not fully sure how it works, but a motor maxing out is the worst thing you can do. Back when the 21.5 and 17.5 motors (novak,LRP,ect.) They had to gear to the moon to prevent overheating. I am a regular on the RC-Monster forums and we got a sort of a guide that is proven for a happy motor.
Hot motor= gear up
Hot esc=gear down
warm on both= perfect gearing
I am running a 23/87 on a 4600 mamba max CM36 motor, running lower gears it heats up, running higher gearing the esc heats up.
My recommendation for you would be to get a 84 tooth spur and see what happens, you should have a 87 right now. You will pick up a couple MPH, but on the track, it will hit top speed closer to the end of the straight. The motor should cool down a bit due to not being maxxed out as much.
The best way to do this is to get a temp gauge/tool and do timed temp checks. Just keep checking and aim for the esc and motor at around the same temp, usually around 140 to 150*f
#465
Good advice.
For that steering link, here it is:
http://www.ebay.com/itm/ALUMINUM-ALL...item53e8f6207a
However, he raised his price $5
Glad I ordered 2 of them right away
another location:
http://www.thetoyz.com/associated/St...80/580/SubCat/
By the way, when you try the steering setup, you may feel as if you want to change something on your car as it will have a whole lot of steering. Don't. First thing I would recommend is dialing down the EXP on your radio so its not so reactive around the lower inputs.
another location:
Thanks .... might even look into just making my own.
