RC10B4.1 FT/WC
http://www.teamassociated.com/cars_a.../Factory_Team/
Maybe the new big bores are those on this truck! Looks like V2 but bigger and they have that retainer that Factory drivers had on their shocks.
GHEA makes the collars and they are nicer in my opinion then using the traxxas stuff. It's my understanding that adjusting with the traxxas stuff is not as easy as using the GHEA collars
I'm throwing Losi springs back on tonight. I'll snap a couple pics with the GHEA collars so you can see it.
never mind, he already did
You may find that with the collars you have to shim out about .050" to avoid hitting the tower. Some guys were just dremeling the tower down a bit too. Either way will work.
.You may find that with the collars you have to shim out about .050" to avoid hitting the tower. Some guys were just dremeling the tower down a bit too. Either way will work.
I'll let them comment on it.
I run them. They help a lot over the whoops at the track I race at and also allow the buggy to go over bumps wide open I was not able to do before
Registered User
