Serpent 811E Buggy Thread >
Like Tree5Likes
Old 01-20-2012 | 11:18 AM
  #1276
Questions?? prokchop's set up
hey Porkchop can u please put up ur latest set up of ur buggy. so i can try on my 811be? thanks buuuuudddddyyyy!
batremi is offline
Old 01-20-2012 | 08:52 PM
  #1277
KIK's Avatar
KIK
Originally Posted by porkchop
we ran on a tight indoor clay track with a few 180s the car just felt good.
set up
diffs
5/5/3
shocks
front
8 hole 1.4 pistons
blue springs
45 wt losi oil
location
3/b
rear
10 hole 5/55 5/56
yellow spring
35wt losi oil
5/b
front insert
0/0
10 deg castor blocks
number 3 rack
sway bars
front 2.5 one mm of slop in the ball at the bottom
i think a 2.3 would been better at the end of the stright but it made the car feel like dumped over to hard ever where eles so we left alone
2.3 rear bar
smooth the car out i thought
rear inserts
6 toe side
5 up squate side
rear link 2/b with the c link i felt my car was to looked into the track for me
front link
2/b
camber
1.5 all around
ride height
27mm all around
wheel base
take all 3 shims out take the two small ones put them on the back side the hub big one front of it.
i hope you guys can try this and it help you with your cars
This was on a tight clay indoor track.
KIK is offline
Old 01-20-2012 | 10:26 PM
  #1278
Frank L's Avatar
Originally Posted by batremi
hey guys. just picked my s811 be up , quality is great!. just wondering . is the buggy great out of the box besides personal set up? like is it a definate that i should get the webbed shock bladders. and is the box set up a good starting point. also i noticed that when mounting the upper shocks to the tower , i noticed on another guys buggy he had a silver coller or washer that goes on after the upper shock is on the pivot mount, i did not notice if they came with my kit . i just mounted the shocks on with the cap hex screw. please help thank you. hey frank l. great video . was the set up u had far from stock ?
That setup was a long way from stock and it was not close to what I'm rolling today. What's on my car today is very close to what porkchop posted above with a few tweaks that are prob track specific on a tight indoor clay high bite track. Outdoor its a little tighter.
Here's a good starting point.
https://docs.google.com/open?id=0B2R...VmNjdkZGRiYmFm
For the upper shock bolt I am using a 3x8 countersunk with a flat head washer
Frank L is offline
Old 01-21-2012 | 06:17 AM
  #1279
rcq
How do you can drive this buggy with hubs forward. With it buggy rear end is very slipping for me. And I use thinner swaybar for front end and tighter swaybar for rear end. When I try thinner foward swaybar I get more stearing on high speed.
What you could surgest for me for better handing for rear end of buggy. Now I run with 5 5 3 diff oil, maybe 5 5 1 would be better?
rcq is offline
Old 01-21-2012 | 07:14 AM
  #1280
bigjayjay1's Avatar
I'm running this setup with small changes like my center diff oil is 3K helps the rear
bigjayjay1 is offline
Old 01-21-2012 | 07:25 AM
  #1281
porkchop's Avatar
rcq my above set up is my base i went to the midwest crcrc champs on a bigger flowing track and made very few changes.
you can change things to make the car better for you.
3k center will smooth power thought the drivetrain and make life better.
2/c rear link also makes the car mega stable
and also my hubs are not all the way forward there big shim front the rest on the back side.
also that rear sway bar imo is what making your car slippry in the rear i felt the car rolled way to much going into a conor then when you slowly turned into the conor more the car rolled over and the rear end let go and sliped out form under the car.
leave your rear diff alone i try that to and felt the car got more inconsistant.
how much run time do you have on your car?
the more run time the more traction it builds
and the age old question are you running the tires the fast guys are?
also thinner front bar would be more steering
also less camber would be more steering
less toe out would be more steering
there a ton of ways to make more steering that people always over look
porkchop is offline
Old 01-21-2012 | 07:28 AM
  #1282
porkchop's Avatar
new notes for my set up
i sent a team driver to the midwest champs with my set up but with a few changes
8x1.3 pistons all around
42.5 front blue spring
32.5 rear with a yellow rear spring
he said the car felt more planted and all around better. so i will be testing that at the next race
porkchop is offline
Old 01-21-2012 | 08:11 AM
  #1283
rcq
Well I am running Jerremy setup, for my both cobra (nitro and electric) but I have miss stearing on speed. After I change thinner front swaybar and tighter rear I feel buggy more strearing but with E-cobra I feel to less rear tracktion.
With E-buggy I do not have a lottof time running but with Nitro I have run all summer season and just at the end of season I found how Cobra have to run.
What realy have lead me is end points of stearing. I always trying do end poind like the other cars , but with cobra I did it a little more on pull for a full stearing. Is it good
For tires yes I allways lookking what are running our fastest driver. Maybe you could advance what should I try for wet clay and about 5 Celsius. Now what we have find the best is Vtec banzai super soft.
rcq is offline
Old 01-21-2012 | 08:29 AM
  #1284
porkchop's Avatar
that the problem you can run a nitro car set up on this car it a total differnt moster. it not the same car it has more weight on the front everthing i know about my nitro car in my nitro book. everthing for my eletric car is in a lil book its getting there nice and slow.
only one thing stay the same my rear shock postion
porkchop is offline
Old 01-21-2012 | 09:50 AM
  #1285
Questions?? tnx frank
thank u Frank. does the eight hole come in the kit or is it an option part. also im about to order the fironi alumn pistons . this means i can use lighter fluids and still have enough pack when landing of big jumps?
batremi is offline
Old 01-21-2012 | 09:51 AM
  #1286
Talking thanks KIK
will it work ok for out doors too. at least as a starting point?
batremi is offline
Old 01-21-2012 | 10:34 AM
  #1287
porkchop, are you going to motorama?
mdmaxx is offline
Old 01-21-2012 | 05:05 PM
  #1288
porkchop's Avatar
i wont know. i not ran outdoor yet lol. give me 4 months lol
not sure yet i did last year and did not have alot fun plus the 6 hour drive
porkchop is offline
Old 01-21-2012 | 05:53 PM
  #1289
BigRon's Avatar
The snake impressed a lot of people today at the track. They liked how it looks on and off the track. I'm pretty sure I've hooked a couple new pilots. I TQ'd the class and won the main by a couple laps. All in all a good day at the track today. The track was a small tight clayish track. I'm still using Chops setup basically. Only difference is I'm running -2.5 camber in the rear for the high speed sweepers that have been part of the last two tracks I've raced on. I was able to carry a lot more speed through the sweeper than the other cars.
BigRon is offline
Old 01-21-2012 | 10:21 PM
  #1290
Conical pistons or stock?
Linkdead is offline
